03-15-2023 12:43 PM
We have a rv340w (1.0.03.29).
Until recently we could vpn throught it using The Greenbow vpn software. It was stable and reliable. Suddenly it stops working. I start looking at it and I realized that the router was not responding to the client vpn software query ''type DPD_R_U_THERE'' with a ''DPD_R_U_THERE_ACK'' and after 3 requests it disconnects. I have to say that the problem appears when the router was at the version 1.0.03.28. I thought that it could be a good thing to refresh it so I flash it to the version 1.0.03.29. But the problem remains.
I have other client with rv340 and rv340w routers so I try to connect to their network utilizing the same laptop with the same vpn software client just to see if I can reproduce the problem. Everything worked fine at my other clients place. And I have exactly the same setup, the same type of vpn, having used the same template for all my clients who needed vpn access.
Idea would be appreciate!
--Connections log of the problematic router. Connection from the Laptop vpn software who tries to connect to the rv340w.
0230315 10:49:31:877 Default (SA MU(1)-Phase2(3)-P2) is opening.
20230315 10:49:32:016 Default (SA MU(1)-P1) SEND phase 1 Aggressive Mode [SA] [KEY_EXCH] [NONCE] [ID] [VID] [VID] [VID] [VID] [VID] [VID] [VID]
20230315 10:49:32:116 Default (SA MU(1)-P1) RECV phase 1 Aggressive Mode [HASH] [SA] [KEY_EXCH] [NONCE] [ID] [NAT_D] [NAT_D] [VID] [VID] [VID] [VID]
20230315 10:49:32:133 Default (SA MU(1)-P1) SEND phase 1 Aggressive Mode [HASH] [NAT_D] [NAT_D]
20230315 10:49:32:136 Default phase 1 done: initiator id blablabla.com, responder id 000.000.000.000
20230315 10:49:32:136 Default (SA MU(1)-P1) renewal in 2295 seconds (11:27:47)
20230315 10:49:32:162 Default (SA MU(1)-P1) RECV Transaction Mode [HASH] [ATTRIBUTE]
20230315 10:49:32:162 Default (SA MU(1)-P1) SEND Transaction Mode [HASH] [ATTRIBUTE]
20230315 10:49:32:291 Default (SA MU(1)-P1) RECV Transaction Mode [HASH] [ATTRIBUTE]
20230315 10:49:32:291 Default (SA MU(1)-P1) SEND Transaction Mode [HASH] [ATTRIBUTE]
20230315 10:49:32:293 Default (SA MU(1)-P1) SEND Transaction Mode [HASH] [ATTRIBUTE]
20230315 10:49:32:321 Default (SA MU(1)-P1) RECV Transaction Mode [HASH] [ATTRIBUTE]
20230315 10:49:32:329 Default (SA MU(1)-Phase2(3)-P2) SEND phase 2 Quick Mode [HASH] [SA] [KEY_EXCH] [NONCE] [ID] [ID]
20230315 10:49:32:428 Default (SA MU(1)-Phase2(3)-P2) RECV phase 2 Quick Mode [HASH] [SA] [KEY_EXCH] [NONCE] [ID] [ID]
20230315 10:49:32:428 Default (SA MU(1)-Phase2(3)-P2) SEND phase 2 Quick Mode [HASH]
20230315 10:49:32:439 Default (SA MU(1)-Phase2(3)-P2) renewal in 3409 seconds (11:46:21)
20230315 10:49:32:547 Default (SA MU(1)-Phase2(3)-P2) [VirtualItf] Virtual Interface properly configured for instance 1 and ItfIndex 3.
20230315 10:50:02:670 Default (SA MU(1)-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE
20230315 10:50:17:752 Default (SA MU(1)-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE
20230315 10:50:32:836 Default (SA MU(1)-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE
20230315 10:50:47:915 Default <MU(1)-Phase2(3)-P2> deleted
20230315 10:50:47:923 Default [VirtualItf] Virtual Interface properly deconfigured for instance 1 and ItfIndex 3.
20230315 10:50:47:924 Default <MU(1)-P1> deleted
-- Connection report to the other routers of my other clients (rv340 and rv 340w) which shows that the connection is successful and that the routers respond to requests from the vpn client software. So for me, it shows that it is not a problem of vpn configuration on the router, (I use the same template for every router) not a problem of ISP, (I try throught 3 ), and not a problem of configuration on the client side, neither hardware.
TheGreenBow VPN Client 6.64.003
20230315 12:18:11:078 Default (SA El-Phase2(2)-P2) is opening.
20230315 12:18:11:111 Default (SA El-P1) SEND phase 1 Aggressive Mode [SA] [KEY_EXCH] [NONCE] [ID] [VID] [VID] [VID] [VID] [VID] [VID] [VID]
20230315 12:18:11:239 Default (SA El-P1) RECV phase 1 Aggressive Mode [HASH] [SA] [KEY_EXCH] [NONCE] [ID] [NAT_D] [NAT_D] [VID] [VID] [VID] [VID]
20230315 12:18:11:260 Default (SA El-P1) SEND phase 1 Aggressive Mode [HASH] [NAT_D] [NAT_D]
20230315 12:18:11:261 Default phase 1 done: initiator id blablabla.com, responder id 000.000.000.000
20230315 12:18:11:261 Default (SA El-P1) renewal in 2513 seconds (13:00:04)
20230315 12:18:11:283 Default (SA El-P1) RECV Transaction Mode [HASH] [ATTRIBUTE]
20230315 12:18:11:284 Default (SA El-P1) SEND Transaction Mode [HASH] [ATTRIBUTE]
20230315 12:18:11:426 Default (SA El-P1) RECV Transaction Mode [HASH] [ATTRIBUTE]
20230315 12:18:11:426 Default (SA El-P1) SEND Transaction Mode [HASH] [ATTRIBUTE]
20230315 12:18:11:427 Default (SA El-P1) SEND Transaction Mode [HASH] [ATTRIBUTE]
20230315 12:18:11:454 Default (SA El-P1) RECV Transaction Mode [HASH] [ATTRIBUTE]
20230315 12:18:11:473 Default (SA El-Phase2(2)-P2) SEND phase 2 Quick Mode [HASH] [SA] [KEY_EXCH] [NONCE] [ID] [ID]
20230315 12:18:11:597 Default (SA El-Phase2(2)-P2) RECV phase 2 Quick Mode [HASH] [SA] [KEY_EXCH] [NONCE] [ID] [ID]
20230315 12:18:11:598 Default (SA El-Phase2(2)-P2) SEND phase 2 Quick Mode [HASH]
20230315 12:18:11:609 Default (SA El-Phase2(2)-P2) renewal in 3340 seconds (13:13:51)
20230315 12:18:11:699 Default (SA El-Phase2(2)-P2) [VirtualItf] Virtual Interface properly configured for instance 1 and ItfIndex 3.
20230315 12:18:41:779 Default (SA El-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE
20230315 12:18:41:802 Default (SA El-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK
20230315 12:19:11:979 Default (SA El-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE
20230315 12:19:12:014 Default (SA El-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK
Any Ideas?
Tx. Pierre
03-15-2023 06:59 PM
check below thread may help you :
03-17-2023 04:22 PM
TX Balaji for answering... but not helpfull.
Like I was saying it is not that I do not know how to configure the rv340 series, I have 7 of them at different place and all my clients use them for vpn and everything is working fine. But I have one rv340w that refuses to do that :
the vpn client : SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE
and the vpn client is supposed to receive from the the router : RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK
I connect succesfully via vpn to all my other rv and they all respond but that one is not!
Any other idea ? Tx
03-17-2023 04:49 PM
I connect succesfully via vpn to all my other rv and they all respond but that one is not! <-- the one not working, I will reset to factory and reconfigure and test and also compare working vs not working what is the different ISP / net connection / is the end user connection issue so on.
if that URL is not helpful, - May be worth contacting SMB TAC.
05-24-2023 11:56 AM
If you have the dpd setting enabled on the router side, then something isn't right and I would try a different firmware version as it might have broke when fixing something else. Otherwise, I would also look at other options that you may have set and check your ha times. You can also try disabling dpd in the greenbow client.
