RV345 Assign web management to specfic vLan
proy1
We have a Cisco RV345 and I have setup two separate vlans each with their own ip ranges. No issues there traffic is segmented and the vlans do not rout to each other. although I can ping the gateway address I can not route across it. I now have two issues, one the web management interface is access able on both vlans. I need it only on one. Second once I have it assigned to one vlan I want to make sure it cannot be access from the second vlan. I stated earlier that I could ping the gateway but not route across it, I would still be able to access the webpage. I have created firewall rules but http and https is not blocked. Thanks for the help,
Paul
ktonev
Hi Paul,
You should be able to achieve this using an ACL rule. If you are experiencing issues please contact our support centre so an engineer can open a service request and assist you in setting up the correct access list.
Kris
I had tried blocking it from the web GUI with a rule to stop all traffic but it still connected. I can't get into the cli as the credentials I set fail.
I will contact support.
Paul
