11-29-2017 01:17 PM - edited 03-21-2019 10:59 AM
We have a Cisco RV345 and I have setup two separate vlans each with their own ip ranges. No issues there traffic is segmented and the vlans do not rout to each other. although I can ping the gateway address I can not route across it. I now have two issues, one the web management interface is access able on both vlans. I need it only on one. Second once I have it assigned to one vlan I want to make sure it cannot be access from the second vlan. I stated earlier that I could ping the gateway but not route across it, I would still be able to access the webpage. I have created firewall rules but http and https is not blocked. Thanks for the help,
Paul
11-30-2017 08:17 AM - edited 11-30-2017 08:17 AM
Hi Paul,
You should be able to achieve this using an ACL rule. If you are experiencing issues please contact our support centre so an engineer can open a service request and assist you in setting up the correct access list.
Kris
11-30-2017 09:30 AM
I had tried blocking it from the web GUI with a rule to stop all traffic but it still connected. I can't get into the cli as the credentials I set fail.
I will contact support.
Paul
