RV345 no access after firmware update to RV34X-v1.0.03.26
sspw
I did a config backup.
I downloaded 1.0.0.3.26 and did the update (without reset to factory checked).
When completed, the webgui login page was corrupt. It had spinning icon beside what should be the login button. see pic.
I tried old logins, but i dont even think the login button is working on login page.
I hard reset the router back to factory defaults.
I can tell this happened as config on LAN1 port changed back to factory defaults (dhcp in 192.168.1.1/24 range was re-enabled).
But i still get corrupted webui on login page.
I can't login in with factory default cisco/cisco.
Is there something i can do with the consoles port? Or is this a brick?
5 Replies 5
marce1000
 - Reboot device with console connected . look for errors during boot. Check this thread on advisories related to console settings : https://community.cisco.com/t5/small-business-routers/cisco-rv345-console-connection/td-p/3063797
 M.
Yes i looked at that post before posting my request.
I dont see any solution, or that either poster asking was able to use the console.
What am i missing?
I connect at 115200-8N1 and get this boot info. But the is not prompt. Hit enter or any kit/combo, does not get a prompt or login.
uloader 2011.06.0 (Apr  5 2019 - 01:30:02)
Board: Mindspeed C2000  900 MHz
nand_probe: comcerto_nand base: 0xc8300000 size: 0x256 MB
ONFI flash detected ... ONFI param page 0 valid
NAND device: Manufacturer ID: 0x01, Chip ID: 0xda (AMD S34ML02G2), page size: 2048, OOB size: 128
Using default values
Using BCH ECC-24
Copying Barebox from NAND Flash(bootopt=2) @offset = 0x0
Reading ...
Done...Bytes read 0x80000
Image verified and authenticated
## Starting Barebox at 0x01000000 ...
barebox 2011.06.0-dirty (Jan  6 2022 - 01:48:08)
calling dus_out_of_reset:
c2k_spi_flash_probe: size : 0x00400000
cbus_baseaddr: 9c000000, ddr_baseaddr: 03800000, ddr_phys_baseaddr: 03800000
class init complete
tmu init complete
bmu1 init: done
bmu2 init: done
util init complete
GPI1 init complete
GPI2 init complete
HGPI init complete
HIF rx desc: base_va: 03e80000, base_pa: 03e80000
HIF tx desc: base_va: 03e80400, base_pa: 03e80400
HIF init complete
bmu1 enabled
bmu2 enabled
pfe_hw_init: done
pfe_firmware_init
pfe_load_elf
pfe_load_elf no of sections: 10
pfe_firmware_init: class firmware loaded
pfe_load_elf
pfe_firmware_init: tmu firmware loaded
pfe_load_elf
pfe_load_elf no of sections: 14
pfe_firmware_init: util firmware loaded
miidev_restart_aneg for PHY5
miidev_restart_aneg for PHY6
ehci@ehci0: USB EHCI 0.01
Using ENV from Fast SPI Flash.
Using BCH ECC-24
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
Malloc space: 0x00800000 -> 0x02000000 (size 24 MB)
Stack space : 0x007f8000 -> 0x00800000 (size 32 kB)
.envfs: wrong magic on /dev/env0
no valid environment found on /dev/env0. Using default environment
running /env/bin/init...
Setting env LAN, WAN1, WAN2...
LAN  MAC : BC:4A:56:02:18:4C
WAN1 MAC : BC:4A:56:02:18:4A
WAN2 MAC : BC:4A:56:02:18:4B
done
Exporting env LAN, WAN1, WAN2...done
FOUND MACs from Boardinfo using same in bootargs
eth0mac = BC:4A:56:02:18:4B, eth1mac = BC:4A:56:02:18:4A, eth2mac = BC:4A:56:02:18:4C
done
Setting active/inactive env...
done
Exporting env...done
active = image1 inactive = image2
Booting default active image1 ...
1.0.02.02
booting kernel of type uimage from /dev/nand0.kernel1.bb
   Verifying Checksum ... OK
   Image Name:   Linux-4.1.8
   Created:      2022-01-05  21:16:55 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2987320 Bytes =  2.8 MB
   Load Address: 03008000
   Entry Point:  03008000
OK
Starting kernel ...
commandline: loglevel=4, panic=10 mac_addr=BC:4A:56:02:18:4B,BC:4A:56:02:18:4A,BC:4A:56:02:18:4C ip=none root=ubi0:rootfs ubi.mtd=4 rootfstype=ubifs rw noinitrd mtdparts=comcertonand:512k(barebox),512k(bareboxfact)ro,128k(env),8M(kernel1),92M(rootfs1),128k(reserved_dtb1),8M(kernel2),92M(rootfs2),128k(reserved_dtb2),2M(configcert),12M(avcsign),32M(webrootdb),2M(license);spi1.0:128k(uloader)ro,512k(barebox),128k(env),128k(boardinfo)ro,64k(md5sum1),64k(md5sum2),64k(boot_check) usb3_internal_clk=yes pcie0_gen1_only=yes pcie1_gen1_only=no  pcie_external_clk=yes bareboxver=barebox 2011.06.0-dirty (Jan  6 2022 - 01:48:08) bareboxver_rv340=1.0.02.02 boot_fail_flag=0
arch_number: 1094
Uncompressing Linux... done, booting the kernel.
The one post discussed baud changes. What baud do in need to get a login prompt that works?
I also tried connecting at 9600 and 19200. Lots of jibberish. Seemingly no change in baud. No prompt appears. Hitting keys also gets no prompt.
                        Hm, I also saw : in your original reply (boot sequence)
   Not sure about the baud rates , I don't use such a device myself I more think the device got bricked (Nand flash memory storage   problem) you may want to have this escalated https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center- contacts.html , the device may need replacement (RMA)
 M.
dan14
The correct baud rate for RV340 is 115200-8N1.
Console port is only active during boot.
You need the power on the router with the console connected and send multiple breaks immediately after you power on the device.
We had this problem with 1.0.03.24
The break will result in booting  the router with an older version firmware.
After this you need to update to  1.0.03.27.
