SRP 527w Automated reset
Hi.
I’m rolling out a fleet of SRP 527W modems for communications support of a remote appliance.  The modems are mostly operating fine, but we have seen one modem’s data rate degrade over time, and eventually drop off the ADSL connection completely.  Power cycling the modem brought it back to life for a time.
I was interested if there was any way that the appliance could request a modem reset without going through the web interface.  In some cases this may save getting a service person out of bed in the middle of the night just to reset a modem.
Best regards,
            Chris Gibson
Hi Chris,
I've raised a case to have the /admin/reboot URL modified to reboot the whole system, rather that just the voice application.
In the mean time, please try the following - it's a little ugly, but should do the trick!
http://[:]/apply.cgi?submit_button=Reboot&gui_action=Apply&need_reboot=1&xuser=admin&xpassword=
Cheers
Andy
6 Replies 6
riroe
Level 3
Level 3
I am not aware of anything that can do this. There is not anything on the Router that can do this
type of function.
THANKS
Rick Roe
Cisco Small Business Support Center
Andrew Hickman
Hi Chris / Rick,
This is possible using the provisioning interface.  To reboot a device remotely, send an HTTP GET to the following URL:
http(s)://[:]/admin/reboot&xuser=admin&xpassword=
Hope this helps,
Andy
[Edit: Sorry, Rick was correct. This URL will only restart the voice application.]
Thanks for the reply Rick and Andrew.
Tryed Andrew's responce before I read the [Edit:... ] note.
The command looked encouraging from the local interface...  Said that it was going to reboot when idle, but nothing happed, as Andrew pointed out this was only for the voice application.  The URL, for any one who wants to reset the voice application locally is(presuming default modem IP address)
http://192.168.15.1/admin/reboot&xuser=admin&xpassword=
Have been attempting to do a similar thing through the web interface, but this is proving tiresome.
Sending the URL
http://192.168.15.1/admin/reboot.asp&xuser=admin&xpassword=>
seems like a decent start, but I will need to follow it up with a POST message that I haven’t quite figured out yet.
Will keep you posted.
Hi Chris,
Cheers
Andy
Thanks Andrew.
Excellent, just what I was looking for.
Best regards,
            Chris Gibson
I realise I'm dragging up a 5 year old threat, but I've been searching and I can't find anything.
This solution doesn't work anymore.  Even though I am giving it the correct username and password, the html I get returned is the login screen.  If I change the xuser or xpassword, I get given a 401. So the user/pass is being accepted, but I'm still not passing some other form of authentication.
I have firmware 1.2.6
Anyone have a solution for this?
