04-29-2012 08:40 PM
Hi Guys,
I've just deployed a SRP527W that I've had lying around for a while.
Everything on the unit runs as well as can be expected, however I have a requirement to run split tunneling for VPN users.
Currently the only route that the VPN client receives is a default route. I noticed that on site to site VPN's and GRE tunnels you can specify secured routes, however I can't find anything that relates to the VPN remote users. This can be done on IOS without a problem but would be nice for the SRP.
I'm running the latest firmware 1.01.26, so if I haven't overlooked something would this be likely for a future release?
Cheers.
Bryce
Solved! Go to Solution.
04-30-2012 05:27 AM
Hi Bryce,
Nothing overlooked, it is not possible to configure split tunnelling for the SRP VPN server.
Andy
04-30-2012 05:27 AM
Hi Bryce,
Andy
05-01-2012 04:39 PM
Hi Andy,
No problems, thanks for your answer.
Hopefully this will pushed as feature to newer firmware.
Cheers.
Bryce
