01-27-2020 03:48 AM
Hi all,
I can't find srp547 firmware. Also, when I examine the logs, the router power / sys light flashes continuously and the ethernet port lights are not on. Interestingly, I access routera web management and it works. Logs are as follows.
I cannot login with ssh and telnet with the default user. I have repeatedly reset hard, but nothing has changed.
I would like your support.
Solved! Go to Solution.
08-20-2021 04:19 AM
yes surely there must be something in archives!
01-27-2020 05:13 AM
Sorry for the inconvenience you are facing. The Cisco Small Business SRP500 Series Services Ready Platforms has been retired and is no longer supported.
End-of-Sale Date: 2013-08-05
End-of-Support Date: 2016-08-31
Please refer the below mentioned link…
Due to that firmware are not available online now.
01-27-2020 09:16 AM
08-20-2021 04:19 AM
