SRP547W | I can't find firmware.
kasimalbayrak
Hi all,
I can't find srp547 firmware. Also, when I examine the logs, the router power / sys light flashes continuously and the ethernet port lights are not on. Interestingly, I access routera web management and it works. Logs are as follows.
I cannot login with ssh and telnet with the default user. I have repeatedly reset hard, but nothing has changed.
I would like your support.
Jan 1 02:00:20 SRP547W kern.err vport_update_link_status: log_port 0 error !
Jan 1 02:00:20 SRP547W kern.err ip_queue: failed to register queue handler
Jan 1 02:00:21 SRP547W kern.err vport_update_link_status: log_port 0 error !
Jan 1 02:00:21 SRP547W daemon.err dnsmasq[1066]: failed to load names from /etc/hosts: No such file or directory
Jan 1 02:00:24 SRP547W kern.err vport_update_link_status: log_port 0 error !
Jan 1 02:00:40 SRP547W kern.err vport_update_link_status: log_port 0 error !
Jan 1 02:00:42 SRP547W kern.err vport_update_link_status: log_port 0 error !
yes surely there must be something in archives!
Sujoy Paria
Sorry for the inconvenience you are facing. The Cisco Small Business SRP500 Series Services Ready Platforms has been retired and is no longer supported.
    End-of-Sale Date: 2013-08-05
    End-of-Support Date: 2016-08-31
Please refer the below mentioned link…
https://www.cisco.com/c/en/us/obsolete/routers/cisco-small-business-srp500-series-services-ready-platforms.html
Due to that firmware are not available online now.
Thank you for return. I know your support is over. If there is a different source I can reach, I opened the subject to be shared.
