Unable to access RV042 after firmware upgrade
After upgrading the firmware of my RV042 router to latest version RV0XX_v4.2.3.14_20200528-code.bin from version 2.2 it's not working. After the upgrade I was not able to access the router using the web interface, then i did a reset, but still not able to reach (now with the standard 192.168.1.1 addresses). It also not replying to ping.
Any suggestions?
6 Replies 6
fmarshall
We have quite a few of these in service and keep the firmware up to date - so lots of interaction with them.
Just a little experimentation might best help with this.
First, be willing to use a number of browsers such as Internet Explorer, Google Chrome and Firefox.  I've not tried the *new* Edge but it's based on Google Chrome I understand.  And, watch out for cached pages.  If you get a failure once, the browser may decide to repeat the failure page instead of getting a fresh one.  Consider flushing the cache.
Next, the addressing can make the difference:
Things to try:
combinations of
https:// << this one most likely
http://
ports 80, 443, 8008,8009,8443
So, you might try this:
http://[ipaddress]:8008
and so forth.
Let us know!
We have tried with different browsers IE,chrome, firefox and new Edge browser too by flushing the cache and haven't found any luck to connect to with and attached the error screenshot
https://192.168.1.1 and also http://192.168.1.1
http://192.168.1.1:8008
http://192.168.1.1:8009
http://192.168.1.1:8443
http://192.168.1.1:443
Sujoy Paria
What is the DIAG LED status showing? Please check whether the NIC connected to RV042 LAN is getting any DHCP IP or not first. In case NIC is showing APIPA IP then you may check once by assigning a static IP on the NIC connected to the RV042 Router LAN port. Assign a static IP (apart from 192.168.1.1) on the NIC from the pool 192.168.1.x /24 and then try to ping 192.168.1.1.
And in case NIC is showing any other DHCP IP then please try to access the RV042 once using the gateway address. Please disable any other NIC in your system along with firewall during troubleshooting.
You may open a service request following the below mentioned link to troubleshoot further…
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
We didnt a DHCP IP address and were getting APIPA IP Address when we connected the LAN ports to directly to Laptop and Then we tried to Assign a static IP address in the range 192.168.1.X/24 and we are able to ping the 192.168.1.1 and then tried to access http:192.168.1.1 and also https://192.168.1.1 but no luck and it says Site cant be reached and try checking the connection.
Attached the Video for the LED Indication of DIAG Status
Did you try in addition, the recommended port numbers like: 80,8080,8008,443?
i.e. https://192.168.1.1:443
http://192.168.1.1:8080
I'm not fully sure which port numbers but believe these are in the list.  You can check.
Conseguiu resolver? estou com mesmo problema!
