02-19-2013 12:44 PM
Comcast installed a new fiber 10M EDI internet connection in our facility the other day and found out it is our responsibility to provide a layer 3 gateway to map the internet connection to the 14 public IP addresses they assigned to us. We are using RV042 for our existing networks with a T1 we had.
Will the RV042 provide the gateway function to route the single IP address comcast provided to the 15 public IP addresses? If so , can you provide the configuration example on this process?
Comcast EDI Connection ---> ???????? ----> 14 Static External Addresses
Interconnect Block 51.235.227.60 / 255.255.255.252.
Comcast Gateway is 51.235.227.61
Clear Layer 3 device WAN interface: 51.235.227.62
Usable IP Block 51.235.227.96/28
Mask: 255.255.255.240
Usable Addresses: 51.235.227.97 - 51.235.227.110
Thanks in advance for your help and advice.
03-21-2013 06:36 AM
Hi Mr. Ken, thank you for using our forum, my name is Johnnatan I am part of the Small business Support community. Well Sr. in this case the RV042 will be no enough for your configuration because it is a Small Business device, I advise you to get an enterprise device to do this job.
You can get more information calling our Pre-sales department, see link bellow: http://www.cisco.com/web/siteassets/contacts/international.html?reloaded=true
I hope you find this answer useful,
*Please mark the question as Answered or rate it so other users can benefit from it"
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
04-01-2013 03:21 PM
Maybe I'm misunderstanding something, but could this not be done using one-to-one NAT?
