12-07-2015 07:27 AM
I want to tag my WAN1 port with at least one VLAN. Indeed my ISP using multiple VLANs (data, VoIP, ...) and unfortually VLAN data is not the native VLAN. :(
Is this feature in the firmware roadmap of RV325? Or how Small Business Routers have this option?
12-08-2015 11:38 AM
I'm intesting too by this capability.
Any idea of an ETA for this option ?
Thanks.
EG
12-22-2015 02:01 AM
I just solved the problem: bought a Draytek 2925
12-24-2015 02:59 AM
Thanks you.
I TEMPORARILY solved this problem by using this tips :
WAN1 ----> LAN14 (untagged VLAN 123) and LAN13 (tagged VLAN 123) ----> ISP
04-25-2021 08:03 AM
Hello Steph' RMS
I have a Cisco RV325. and have the same probelm. Would you please share with me how did you do this?
For example Did you use a cable to connect WAN to LAN 14?
VLAN 2 and VLAN 3 doesnt exist.
VLAN1 doesnt allow you to chang from untagged(default) to tagged.
I will really appreciate your help.
Thank you in advance.
SunnyJi
07-19-2021 02:14 AM
Did you solved?
I have the same problem, my ISP needs VLAN 835
Thank you
07-19-2021 02:50 AM
07-19-2021 02:06 PM
I tried to do this connection but it does not work at all (it is not possible to connect to the router anymore)
created the VLAN 835 (my ISP)
set port 7 as tagged
set port 14 as untagged
connect port 14 to WAN
connect ISP cable to Port 7
