VLAN on a WAN port of RV325 Cisco Routers
Steph' RMS
I want to tag my WAN1 port with at least one VLAN. Indeed my ISP using multiple VLANs (data, VoIP, ...) and unfortually VLAN data is not the native VLAN. :(
Is this feature in the firmware roadmap of RV325? Or how Small Business Routers have this option?
7 Replies 7
Eric Guesney
I'm intesting too by this capability.
Any idea of an ETA for this option ?
Thanks.
EG
NunoGuerra
I just solved the problem: bought a Draytek 2925
Thanks you.
I TEMPORARILY solved this problem by using this tips :
WAN1 ----> LAN14 (untagged VLAN 123)  and LAN13 (tagged VLAN 123) ----> ISP
SunnyJi
Hello Steph' RMS
I have a Cisco RV325. and have the same probelm. Would you please share with me how did you do this?
For example Did you use a cable to connect WAN to LAN 14?
VLAN 2 and VLAN 3 doesnt exist.
VLAN1 doesnt allow you to chang from untagged(default) to tagged.
I will really appreciate your help.
Thank you in advance.
SunnyJi
Did you solved?
I have the same problem, my ISP needs VLAN 835
Thank you
Nope not solved. I came to understand that the router doesn't support such
a function. It would be great if anyone has a solution
I  tried to do this connection but it does not work at all (it is not possible to connect to the router anymore)
created the VLAN 835 (my ISP)
set port 7 as tagged
set port 14 as untagged
connect port 14 to WAN
connect ISP cable to Port 7
