Why are there so many duplicate entries in my rv042 Incoming Log Table?
avdiscolo
Can someone please decode this log for me?  Thanks.
Incoming Log Table
Time
Event-TypeMessage
Jan 6 20:25:28 2012   Connection Refused - Policy violation   TCP 192.168.0.28:51210->192.168.0.1:2555 on ixp0
Jan 6 20:23:56 2012   Connection Refused - Policy violation   TCP 192.168.0.28:51204->192.168.0.1:2555 on ixp0
Jan 6 20:23:14 2012   Connection Refused - Policy violation   TCP 95.211.45.248:46542->50.106.18.26:22 on ixp1
Jan 6 20:23:14 2012   Connection Refused - Policy violation   UDP 192.168.0.128:138->192.168.0.255:138 on ixp0
Jan 6 20:21:50 2012   Connection Refused - Policy violation   TCP 192.168.0.28:51185->192.168.0.1:2555 on ixp0
Jan 6 20:19:15 2012   Connection Refused - Policy violation   TCP 74.125.127.139:80->50.106.18.26:34142 on ixp1
Jan 6 20:08:04 2012   Connection Refused - Policy violation   TCP 121.9.206.209:6000->50.106.18.26:3389 on ixp1
Jan 6 20:04:17 2012   Connection Refused - Policy violation   TCP 184.173.100.114:55627->50.106.18.26:64660 on ixp1
Jan 6 20:04:03 2012   Connection Refused - Policy violation   TCP 184.173.100.114:55627->50.106.18.26:64660 on ixp1
Jan 6 20:01:44 2012   Connection Refused - Policy violation   TCP 115.38.115.127:3702->50.106.18.26:445 on ixp1
Te-Kai Liu
Level 7
Level 7
There was a known issue about bogus logs in an earlier firmware release. Are you running the latest firmware 4.1.0.02?
Thank you for the reply.  I am currently running the 1.3.12.19-tm (Feb 13 2009 13:03:21) firmware.
I don't think I have the v2 hardware.  How can I tell if I can install the 4.x.x.x firmware?
If your RV042 is Linksys branded, my previous posting is not applicable.
Regardless which hardware version you have, RV0xx will log a message for each refused incoming packet. You might want to give a call to the Support Center in case you have any connectivity issue.
