WRV210 Help
jmcelroy
I recently purchased a WRV210 router.  I'm trying to set it up and right now I have my server acting as my DHCP server.  I can not change this.  How can I have the WRV210 recoginize this and pick up on this so that computers connected wirelessly to it will receive IP Addresses from my DHCP Server and not from the router?  Right now if I turn all DHCP off, I'm unable to connect to the router.
J
jmcelroy
*BUMP*
Hi Josh,
Thank you for posting in the community.  Since you just purchased the WRV210, I suggest that you call the Small Business Support Center. The phone numbers in your area is located here:
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
jmcelroy
They were able to resolve the issue.  The solution turned out to be very simple, so simple in fact it's almost embarrassing to post.  All I had wrong, was that the network cable that connects the router to my network had to go into one of the LAN ports and not into the Internet port.  Setup the Static IP address, turned DHCP off, plug the network cord into the right port and it worked perfect.
