WRV210 VPN responds - "The remote gateway is not responding. Do you want to wait."
neil.christie
I am trying to set up a VPN to my network with a WRV210 Router.
From outside the network using the QuickVPN client, I get as far as "Verifying network" followed by "The remote gateway is not responding. Do you want to wait."
The VPN Status shows a start time and a stop time against the user, about 1/2 to 1 minute apart.
I am getting internet access to adminster the router over the internet.
Any ideas gratefully received.
Neil
5 Replies 5
linksysinfo
Level 4
Level 4
what does the log report?
C:\Program Files\Cisco Small Business\QuickVPN Client\Log.txt
Regards Simon
Here is content of log.txt
I assume I have a firewall problem
2011/08/31 09:11:18 [STATUS]OS Version: Windows 7
2011/08/31 09:11:18 [STATUS]Windows Firewall Domain Profile Settings:  OFF
2011/08/31 09:11:18 [STATUS]Windows Firewall Private Profile Settings: OFF
2011/08/31 09:11:18 [STATUS]One network interface detected with IP address 192.168.0.15
2011/08/31 09:11:18 [STATUS]Connecting...
2011/08/31 09:11:18 [DEBUG]Input VPN Server Address = 82.152.170.237
2011/08/31 09:11:18 [STATUS]Connecting to remote gateway with IP address: 82.152.170.237
2011/08/31 09:11:20 [STATUS]Remote gateway was reached by https ...
2011/08/31 09:11:20 [STATUS]Provisioning...
2011/08/31 09:11:31 [STATUS]Success to connect.
2011/08/31 09:11:31 [STATUS]Tunnel is configured. Ping test is about to start.
2011/08/31 09:11:31 [STATUS]Verifying Network...
2011/08/31 09:11:37 [WARNING]Failed to ping remote VPN Router!
2011/08/31 09:11:40 [WARNING]Failed to ping remote VPN Router!
2011/08/31 09:11:43 [WARNING]Failed to ping remote VPN Router!
2011/08/31 09:11:46 [WARNING]Failed to ping remote VPN Router!
2011/08/31 09:11:49 [WARNING]Failed to ping remote VPN Router!
2011/08/31 09:11:53 [WARNING]IKE was blocked, which can be caused by a firewall blocking the UDP port 500 or 4500.
2011/08/31 09:12:24 [STATUS]Disconnecting...
2011/08/31 09:12:30 [STATUS]Success to disconnect.
Neil--Check under your router firewall settings and make sure that you have Block WAN Requests Disabled.
THANKS
Rick Roe
Cisco Small Business Support Center
I am still struggling with this issue. I have tried disabling all the firewall settings in the router and the firewall on the laptop. I can ping e.g. bbc.co.uk and my own IP address form the internet but am still getting the message "The remote gateway is not responding. Do you want to wait." and the following recorded in the log file: -
2011/09/05 15:47:57 [STATUS]Success to connect.
2011/09/05 15:47:57 [STATUS]Tunnel is configured. Ping test is about to start.
2011/09/05 15:47:57 [STATUS]Verifying Network...
2011/09/05 15:48:03 [WARNING]Failed to ping remote VPN Router!
2011/09/05 15:48:06 [WARNING]Failed to ping remote VPN Router!
2011/09/05 15:48:09 [WARNING]Failed to ping remote VPN Router!
2011/09/05 15:48:12 [WARNING]Failed to ping remote VPN Router!
2011/09/05 15:48:15 [WARNING]Failed to ping remote VPN Router!
2011/09/05 15:48:19 [WARNING]IKE was blocked, which can be caused by a firewall blocking the UDP port 500 or 4500.
2011/09/05 15:48:23 [STATUS]Disconnecting...
2011/09/05 15:48:28 [STATUS]Success to disconnect.
What am I missing here?
Neil
Hi Neil,
With Windows 7 and Vista the Windows Firewall MUST be enabled. The symptom you are seeing is very common when there is third party antivirus or firewall software on the PC. Disable or remove all such software. After you establish a QuickVPN connection you can work on making that software play nice with QuickVPN. From the logs it appears that the connection is almost established but something on your PC is blocking the ping response from the router. Does the VPN status in the router show that you are connected?
