11-01-2010 09:19 PM
I have configured my WRVS-4400N with 3 separate VLANs. I have intra-VLAN routing turned off because I do not want any traffic between the VLANs.
EXCEPT, I would like 1 computer on my Point-of-Sale VLAN to be able to communicate with 1 printer on my Office VLAN.
What is the best way to accomplish this? Can I create a single static route between the IPs?
11-03-2010 06:44 AM
Hi CJ,
One way you could accomplish this would be to enable the Inter-VLAN routing, then create an IP based ACL to block the DHCP range assigned to each VLAN to everything else except this single IP address.
With Inter-VLAN routing disabled, it will function as you have seen and not allow traffic from one VLAN to another.
Thanks!
Dave
11-03-2010 11:03 AM
OK, I can deffnately do that. But doesn't enabling intra-vlan routing just create routes in the routing table? Is there no way to create a single static from an IP on one VLAN to an IP on another VLAN without turning on intra-vlan routing? I tried to do this, but when I set the router for the route as 0.0.0.0 I got an error.
Maybe I'm paranoid, but I love the simplicity of VLAN security vs IP packet blocking using a firewall.
-CJ
11-03-2010 11:17 AM
Hi CJ,
You can certainly do routes, however you'd have to have a route for each IP address in each VLAN.
I believe the simpler answer would be as described above with Enabling Inter-VLAN routing, then ACL to block a subnet or range depending on how your network is configured and IP that your printer is on.
Thanks!
Dave
