Hi,I recently installed a WRVS4400N router on my home network. Prior to that I was using the wireless built into my FIOS router. I wanted something more secure so I went with the WRVS4400N. I turned off the FIOS wireless and am only using the cisco wireless.
Im having intermittent issues with the wireless. I have many things hooked up to my wireless including a HP printer and a Sonos system. Most of the time if I just open my ipad I cannot see anything else on my network including the printer. If I try to see the Sonos system can cannot, sometimes I can open the app on my iphone and then I can see it.
Sometimes I can see the printer and sometimes I cant. Sometimes when I do see it and then print to it, it will be gone before it even prints.
I don’t seem to have any issues thru the LAN connections.
Also, ive noticed that the wifi is much slower than the old FIOS box.
FYI, when I remove the cisco and fire back up the FIOS wifi I don’t have any problems at all at any time. And its much faster.
I have tried channel 6, 11 and auto. Also turned off IPC and still no change.
Any idesas or help would be appreciated.
Thank You
