BFD + static route + sub interface
Luca CQ
Visitor
Hi all
Question about this scenario:
ASR 1009-X , IOS_XE linked to another router by interface g0/1.
Customer has vrf TEST and wants 2 subnet p2p/31 configured on sub-interfaces as follows:
g0/1.10  --> ip adrr 10.10.10.1/31   (other router has .2)
g0/1.20  --> ip adrr 20.20.20.1/31   (other router has .2)
Need to configure BFD.
Questions are:
1) the BFD route static config can (or have to) be bold to sub-int ?   (i didn't found examples in Cisco BFD config Guides)
2) does it need to be bold to VRF TEST?    (i've doubt because the next hop is in VRF TEST)
3) is it enough to config only one static? or must be configured both?    (i've doubt because the physical interface is the same g0/1)
Is this configuration correct?:
ip route static bfd  g0/1.10  10.10.10.2
ip route static bfd  g0/1.20  20.20.20.2
ip route vrf TEST  1.1.1.0  255.255.255.0   g0/1.10  10.10.10.2
ip route vrf TEST  2.2.2.0  255.255.255.0   g0/1.20  20.20.20.2
thanks a lot to anyone who will reply
Luca
hostname IOU1
ip vrf MHM
rd 1:100
interface Ethernet0/0
no ip address
interface Ethernet0/0.10
encapsulation dot1Q 10
ip vrf forwarding MHM
ip address 10.0.0.10 255.255.255.0
bfd interval 50 min_rx 50 multiplier 3
interface Ethernet0/0.20
encapsulation dot1Q 20
ip address 20.0.0.10 255.255.255.0
ip route static bfd Ethernet0/0.10 10.0.0.20
ip route static bfd Ethernet0/0.20 20.0.0.20
ip route vrf MHM 22.22.22.22 255.255.255.255 Ethernet0/0.10 10.0.0.20
ip route vrf MHM 33.33.33.33 255.255.255.255 Ethernet0/0.20 20.0.0.20
I run this lab for you
hope it help you
6 Replies 6
balaji.bandi
Not sure if i understand correctly bare with me, if both are the same VRF, why do you need static routing ?
have this sub-interface configured with VRF interface - what config you have ?
why do you need BFD what is the use case here ?
check some references:
https://community.cisco.com/t5/service-providers-knowledge-base/bfd-support-on-cisco-asr9000/ta-p/3153191
BB
I dont get what try here
the next-hop is direct connect and you use egress interface why BFD ?
Luca CQ
Visitor
Hello  @balaji.bandi  , @MHM Cisco World  and thanks for your replies
yes sub-interfaces are in the same VRF TEST:
g0/1.10
--> ip adrr 10.10.10.1/31, vrf forwarding TEST, encap dot1q 10, etc          (remote router has 10.10.10.2)
g0/1.20 --> ip adrr 20.20.20.1/31, vrf forwarding TEST, encap dot1q 20, etc          (remote router has 20.20.20.2)
but the subnet to reach are:
1.1.1.0/24
2.2.2.0/24
that are the subnet assigned to the platforms that are "behind" the remote router that has the other ip addresses (the .2) of the two p2p/31, and customer askes for static routing through those subif/vlans (10 and 20) + BFD to check and manage this reachability, may be a switch in the middle actually i don't know 🙂
Yes I get
I will run lab
first you have VRF
second you have subinterface
hostname IOU1
ip vrf MHM
rd 1:100
no ip address
hope it help you
hi @MHM Cisco World , thank you!
so it works with subinterfaces in the
ip route static bfd
commands, great
thank you for your support and time
