BGP flapping
dtwoods83
Level 3
Level 3
Can BGP flap becasue of an over utilized interface? If so why would it flap? Is it becasue the hold timers are timing out?
2 Accepted Solutions
I guess your explanation answered your own question. The overutilized interface looked to BGP like a down interface, so it was flapping...
balaji.bandi
If you do not like the BGP to flap, then reserve some bandwidth to BGP, using policy map :
you can find example :
https://community.cisco.com/t5/routing/bgp-flapping-issue-due-to-over-utilization-of-link/td-p/889873
BB
5 Replies 5
Georg Pauwen
I guess a heavily overutilized interface would drop traffic because the buffers cannot handle the amount of packets. If BGP keepalives do not make it through either, BGP would flap.
The link was 90 to 100 percent overutilized. The core switch was doing the load balancing for both routers. I shut down the connection from the core going to the router that BGP was flapping and overutilized on. The flapping stop almost right away. I was not sure if it was coincidence or not. When I brought the connection back up the switch was load balancing correctly again and did not see any flaps.
balaji.bandi
BB
