BGP Flapping Issue due to over utilization of link
zanderzone
Can we find a way to enhance BGP stability when we are running on reduced IMA bandwidth.
Our router has 3xT1 IMA, when all 3 T1s are running properly, we have no problems. When a Layer 1 issue occurs on one of the T1s (reduced bandwidth) then the router becomes highly unstable (BGP timeouts/flapping). BGP flaps continuously when we lose a T1, and then the service is unavailable.
Is there a way to create a policy map that will give BGP priority, so we will not experience an "outage" during a layer 1 issue? In other words, BGP will get a level of priority to insure it does not FLAP continuously.
bvsnarayana03
Level 5
Level 5
I also thought policy-map could be of help here. But one thing to note, best practice is to create a bgp neighbor with loopback address & not physical interface address. If your neighbor is configured on physical interface address & that interface goes down, then you'll loose connection. But if you are already using loopback for neighborship, the here is the policy-map:
BGP runs by establising tcp connection with neighbor over port 179. So you may cretae a policy map & reserve BW for connections with tcp port 179.
access-list 101 permit tcp any any eq 179
clas-map neighbors
match access-list 101
policy-map bgp
class neighbors
bandwidth 100
apply this policy-map to either the physical links or multilink connecting to the neighbor devices.
hope that clarifies.
pls rate all helpful posts.
As BVS said, it is always advisable to use the loopback interfaces with BGP
So in case you use loopbacks just prioritise all the traffic between the 2 loopbacks using an access-list which will prioritise all the BGP traffic
access-list BGP permit ip host Loop1 hostloop2
access-list BGP permit ip host Loop2 host loop1
clas-map match-all BGP
match access-list name BGP
policy-map bgp
class BGP
bandwidth 100
Apply this policy on the interface on both ends of the routers
Narayan
HI,
In addition to BVS and Narayan:
Loopback IP Address can be used in BGP for Tunnel Source and Destination. That should be highly enough.
>>If you have enough Bandwidth there is no need for reserving BW to Port 179 - the BGP TCP connection port.
Since you have overloaded Link pls go-ahead with their advices.
DO RATE ALL HELPFUL POSTS
Best Regards,
Guru Prasad R
