C1161X-8P basic setup without NAT
markagregory
Visitor
Hi, I'm stuck and would appreciate some help.
My config is attached. Currently the acls are
ip access-list extended InsideToOutside_acl
10 permit ip any any
ip access-list extended OutsideToInside_acl
if I change OutsideToInside_acl to be
10 permit tcp any any eq 3389
I find that RDP can be used to connect from the Internet to LAN computers but LAN traffic to the Internet (or more likely the return traffic) stops.
How can I fix this?
Hello
Try the following:
no policy-map type inspect avc Web_app_policy
no class-map type inspect match-all InsideToOutside
interface GigabitEthernet0/0/0
no ip access-group OutsideToInside_acl in
interface GigabitEthernet0/0/1
interface GigabitEthernet0/1/0
no ip access-group InsideToOutside_acl in
access-list 110 remark RDP
access-list 110 permit tcp any any eq 3389
access-list 110 permit udp any any eq 3389
class-map type inspect match-any InsideToOutside  < you may have to remove the old class map before adding this
match protocol icmp
match protocol dns
match protocol http
match protocol https
match access-group 110
class-map type inspect match-any OutsideToInside
no match access-group name OutsideToInside_acl
Kind Regards
Paul
6 Replies 6
balaji.bandi
when you have this config all works ?  ( then above still allow 3389 port part of any any right ?) are you able to connect 3389 ?
BB
Hello
Try the following:
match protocol icmp
match protocol dns
match protocol http
Kind Regards
Paul
Hi @paul driver
thank you, this is exactly what I needed to get back on track. I think I was mixing two forms of packet access management.
One minor modification is needed. I would like to limit traffic coming in to 3389, but I don't want to limit traffic going out.
I understand that this command is limiting what packets can go out?
description InsideToOutside
match protocol icmp
match protocol dns
match protocol http
How do I permit all traffic to go out from the user machines?
Mark
Georg Pauwen
I have not read through all the other posts, but zone based firewalls and access lists applied to zone member interfaces don't work well together.
Make the changes marked in bold, this allows all traffic outbound, and only RDP 3389 inbound. That said, you do not have any NAT configured, is that on purpose ?
Current configuration : 23172 bytes
! Last configuration change at 17:36:35 UTC Thu Jul 1 2021 by admin
version 16.12
service call-home
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
hostname netlab
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authentication login a-eap-authen-local local
aaa authorization exec default local
aaa authorization network a-eap-author-grp local
aaa login success-track-conf-time 1
aaa session-id common
clock timezone UTC 10 0
clock summer-time UTC recurring 1 Sun Oct 1:00 1 Sun Apr 1:00
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
no destination transport-method email
no ip domain lookup
ip domain name sece.company.com
ip dhcp excluded-address xxx.xxx.68.0 xxx.xxx.68.29
ip dhcp excluded-address xxx.xxx.68.50 xxx.xxx.68.255
ip dhcp pool VLAN68Pool
network xxx.xxx.68.0 255.255.255.0
default-router xxx.xxx.68.254
dns-server xxx.xxx.68.254 8.8.8.8
lease 7
login on-success log
subscriber templating
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
crypto pki trustpoint quovadis.root
enrollment terminal pem
revocation-check none
crypto pki trustpoint quovadis.inter
serial-number none
fqdn netlab.sece.rmit.edu.au
ip-address none
subject-name C=xxxx
subject-alt-name netlab.company.com
chain-validation continue quovadis.inter2
rsakeypair netlab.company.com 2048
crypto pki trustpoint quovadis.inter2
chain-validation continue quovadis.root
crypto pki certificate chain SLA-TrustPoint
certificate ca 01
30820321 30820209 A0030201 02020101 300D0609 2A864886 F70D0101 0B050030
quit
crypto pki certificate chain quovadis.root
certificate ca 445734245B81899B35F2CEB82B3B5BA726F07528
30820560 30820348 A0030201 02021444 5734245B 81899B35 F2CEB82B 3B5BA726
quit
crypto pki certificate chain quovadis.inter
certificate 234A05CD947BCE0C6C755EE05B1447CEA6DD3E68
3082071C 30820504 A0030201 02021423 4A05CD94 7BCE0C6C 755EE05B 1447CEA6
quit
certificate ca 2D2C802018B7907C4D2D79DF7FB1BD872727CC93
308206AB 30820493 A0030201 0202142D 2C802018 B7907C4D 2D79DF7F B1BD8727
quit
crypto pki certificate chain quovadis.inter2
quit
crypto pki certificate pool
cabundle nvram:ios_core.p7b
license feature hseck9
license udi pid C1161X-8P sn F
license boot level securityk9
memory free low-watermark processor 70177
diagnostic bootup level minimal
username admin privilege 15 password 0 xx
username Wb35lMa26ZzB password 0 xx
redundancy
mode none
crypto ikev2 proposal netlab.company
encryption aes-cbc-256
integrity sha256
group 14
vlan internal allocation policy ascending
track 1 ip sla 1 reachability
match access-group name InsideToOutside_acl
class-map type inspect match-all OutsideToInside
description OutsideToInside
policy-map type inspect INSIDE-OUTSIDE-POLICY
class type inspect InsideToOutside
inspect
class class-default
drop log
policy-map type inspect OUTSIDE-INSIDE-POLICY
class type inspect OutsideToInside
--> pass
class class-default
drop log
zone security INSIDE
description Zone for inside interfaces
zone security OUTSIDE
description Zone for outside interfaces
zone security default
zone-pair security INSIDE-OUTSIDE source INSIDE destination OUTSIDE
service-policy type inspect INSIDE-OUTSIDE-POLICY
zone-pair security OUTSIDE-INSIDE source OUTSIDE destination INSIDE
service-policy type inspect OUTSIDE-INSIDE-POLICY
description WAN GE 0/0/0
ip address xxx.xxx.253.10 255.255.255.240
--> no ip access-group OutsideToInside_acl in
zone-member security OUTSIDE
negotiation auto
description WAN GE 0/0/1
no ip address
negotiation auto
description VLAN68Port0
switchport mode access
--> no ip access-group InsideToOutside_acl in
zone-member security INSIDE
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
interface Vlan1
description VLAN68
ip address xxx.xxx.68.254 255.255.255.0
interface Vlan2
no ip address
ip forward-protocol nd
ip http server
ip http authentication aaa
ip http secure-server
ip http timeout-policy idle 600 life 600 requests 25
ip route 0.0.0.0 0.0.0.0 xxx.xxx.253.13
--> permit tcp any any eq 3389
control-plane
line con 0
stopbits 1
line vty 0 4
exec-timeout 60 0
length 0
end
Hi @Georg Pauwen
thank you for your response. I followed your guide and I can no longer connect from outside to inside using RDP. I have carefully checked my edits.
I do not use NAT, because I have a public class C behind the device that I use. This is a historic implementation.
I would appreciate asking a couple of clarifying points to try to fix the problem.
1. the line --> pass
I'm assuming that I simply enter pass and hit return
2. the line permit tcp any any eq 3389
should that have a number in front?
e.g. the other statement has
thank you
Mark Gregory
Indeed, pass is just one line.
For the access list you don,'t need a sequence number, since it only has one line anyway...
