CLI problem!
ferencdeli
Community Member
So...
http://www.cisco.com/en/US/docs/wireless/access_point/1130/quick/guide/ap1130qs.html#wp39091
step 1 : configure terminal    enter global configuration mode           hahhh its not easy
I see the hyperterminal on the console port
*Mar  1 00:00:06.284: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power s
ource
*Mar  1 00:00:06.293: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1130 Software (C1130-RCVK9W8-M), Version 12.3(11)JX1, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 17-Jul-06 11:38 by alnguyen
*Mar  1 00:00:07.248: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to
up
*Mar  1 00:00:08.248: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0, changed state to down
*Mar  1 00:00:25.300: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
Cisco>en
Password:
Cisco#Configure terminal
% Invalid input detected at '^' marker.
Cisco#?
Exec commands:
  cd               Change current directory
  clear            Reset functions
  clock            Manage the system clock
  crypto           Encryption related commands.
  debug            Debugging functions (see also 'undebug')
  delete           Delete a file
  dir              List files on a filesystem
  disable          Turn off privileged commands
  enable           Turn on privileged commands
  exit             Exit from the EXEC
  fsck             Fsck a filesystem
  help             Description of the interactive help system
  led              LED functions
  lock             Lock the terminal
  login            Log in as a particular user
  logout           Exit from the EXEC
  lwapp            lwapp exec commands
  mkdir            Create new directory
  more             Display the contents of a file
  name-connection  Name an existing network connection
  no               Disable debugging functions
--More--
Where is the config ??
Type:air-lap1131g-e-k9
how i see the ip for the CLI my browser? 10.0.0.1 not good
Thanks.
drstokes76
Community Member
Daft suggestion but its not case-sensitive on that version is it?
The marker is: config terminal
aaaaaaaaaaaaa^aaaaaaaaaa
o letter because the c is OK but this notepad left the marker
i try 3-5 days anythink
not simple problem
and where is the configure at after ?
not solve
zdesve33
Community Member
i think, you are running this ap in lwapp mode. try this doc http://www.cisco.com/en/US/partner/docs/wireless/access_point/1130/installation/guide/113h_c4.html#wp1091047 to return to autonomous mode. in lwapp mode you cannot configuring ap, ap is configuring by controller.
Leo Laohoo
This is the reason why.  You are running an LWAP-IOS.
