10-08-2019 11:23 AM - edited 10-08-2019 12:25 PM
Hi All,
what is the purpose of using a ACL that is not defined on a VLAN or an Interface?
interface Vlan50
ip address 10.200.96.1 255.255.255.0
ip access-group 130 in
"access-list 130" doesn't exist on rest of the config
Solved! Go to Solution.
10-08-2019 11:49 AM
somebody probably forgot to remove it, or has put it in there for future use. An access-group without an existing access list to match has no effect, that is, all traffic is allowed.
If you are in charge of the network, I would remove the line as it can cause confusion.
10-08-2019 11:49 AM
10-08-2019 11:50 AM
then that config is redundant and it not have any effect at all.
=====️ Preenayamo Vasudevam ️=====
10-08-2019 11:52 AM
This seems a mistake and looking that the admin may forget to add or remove from the configuration. This is not doing anything and allowing everything.
