Flapping interface
julio.fojon
Community Member
I am having the following issue. My MetroE connection bounces from time to time, due to this the router starts trying to fallback and restore the connection until it gets stock. I would like to know if there is a command that I can enter on the interface (or router) in order for me to delay the MetroE interface recovery so the router can completely fallback.
For example, provide the interface with about 2 minutes before it gets recognize as active again by the router. Eigrp is enable on that interface.
Thanks.
Edison Ortiz
Julio,
You haven't mentioned the hardware being used for the MetroE but ip dampening may be something that can help:
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t13/feature/guide/ftipevdp.html
HTH,
__
Edison.
Edison,
Thank you for your suggestion but this command does not apply to my configuration since one of its restrictions is that it can't track subinterfaces which is what I have configured.
Any other suggestions?
Thank you.
Sorry, I don't have any.
__
Edison.
