Flexconfig EIGRP setup on Sourcefire 2130
0rsnaric
Level 4
Level 4
Does anybody have a configuration example for setting up EIGRP on the Sourcefire 2130? Preferably via FDM, and not FMC.
All of the Cisco docs I have found just go over generic flexconfig setups. Nothing specific to EIGRP.
Thanks!
balaji.bandi
i was not used FDM for Long we use most of time only FMC
but as per document :
EIGRP
FlexConfig
Configure EIGRP using FlexConfig objects from the Device > Advanced Configuration page.
check if that works
https://www.cisco.com/c/en/us/td/docs/security/firepower/660/fdm/fptd-fdm-config-guide-660/fptd-fdm-routing.html
BB
balaji.bandi
EIGRP
FlexConfig
check if that works
BB
Thank you.
This ended up being nothing more than a typical eigrp setup reduced to variables and templates.
No idea why they are pushing template based networking to smaller shops. I have no need to deploy this config to multiple devices...just one.
