Internet access problem
imran_imu
Community Member
Dear all
with respect i am informing you that i am facing some connectivity problem.
Problem: A new branch is added with head office.Users of head office can access internet but how will i configure the branch router to access internet of LAN users.
I have given the diagram with attachment for understanding better.
If posible please give the router configuration.
spremkumar
Level 11
Level 11
You need to include the remote lan network also on your NAT statements so that they will also get natted.
Can you post your current config of your router which is getting connected to the internet ?
regds
rajinikanth
Level 6
Level 6
Try to add a default route on branch router.
branch(config)# ip route 0.0.0.0 0.0.0.0
raj
Hi Imran,
As per the diagram and your said, the branch office and head office have connected.
Only head office have internet connectivity and branch have need to come head office for internet access.
Now you need to configure a default route on your branch office router pointing to your head office (any vlan)
Say you have vlan11 and 12 in head office and both have internet access.
Then config like below at your branch office router
0.0.0.0 0.0.0.0 10.250.1.1 (assuming 10.250.1.1 is your vlan11)
Please rate if this helps you..
Naidu.
Hi Naidu,
Great your explainations, it seems me even non tech guy (who is new to technology) also can easily understand your points.
Jopeti.
