Regarding etherport loopbacks
ncnaveen_arasu
Level 4
Level 4
Dear Team,
How to enable or check loop on ethernet interfaces as we do in serial links for testing the connectivity between end to end on point to point links.
when do we use the loopback internal command.
Thanks in advance.
Naveen
paolo bevilacqua
No really needed. Assume the port is working until proven otherwise.
Hi Paolo Thanks for the reply,
It's needed when we have an WAN termination in Ether output. So how can we check in this scenarios when we used Ethernet terminations for WAN links.
