Strange EIGRP problem
jorgecorrales1
Community Member
Hi there.
I have three equipments in the same LAN. One 6500 switch, one 2800 router and one very old 1600 router. The thing is 2800 and 6500 can establish EIGRP neighborhood. Neither 6500 nor 2800 can establish EIGRP neighborhood with 1600 router. 6500 and 2800 added 1600 on their Neighbor tables, but 1600 didn't.
I run "debug eigrp packets hello". All of them send Hello messages, but for some reason 1600 does not see Hello packets from other equipments. 1600 is connected via serial interface with other router and they could establish neighborhood. I wonder if it is some issue with 1600 Ethernet interface.
Any ideas?
Thanks.
18 Replies 18
Edison Ortiz
Can you post configs along with show ip eigrp interface and show ip proto from each device ?
Is there any access-list configured on the ethernet interface of the 1600?
If yes, then it should allow the eigrp protocol to successfully exchange hellos and establish adjacencies.
Narayan
Thank you very much for your answers. There is not access-lists configured on 1600. Right now I am out office, until next monday. I will send the output of the commands you asked for, I am not sure I would be able to send the complete configuration, but I can answer specific configuration questions. Thank you bery much.
One more thing I did'nt metion before, while I am not able to see Hello packets on 1600, I CAN see other type of EIGRP packets (Update packets, for instance).
Thank you very much.
Jorge Corrales
Hellos are Multicasts. Can problem be in Multicasts?
minumathur
Level 5
Level 5
EIGRP will not form neighborship if "K" value mismatch, Please check
You can also send config and debug informations.
-Minu
deepinder
Try using the "neighbor" command under router eigrp in all 3 (2800, 6500, 1600).
These are outputs for "sh ip eigrp interfaces" and "sh ip proto" commands. The network in which all of them should establish neighborbood is 10.149.224.0/22
I had to split the message becuase it was so long
6500
IP-EIGRP interfaces for process 2146
Xmit Queue Mean Pacing Time Multicast Pending
Interface Peers Un/Reliable SRTT Un/Reliable Flow Timer Routes
Gi1/1 1 0/0 1 0/10 50 0
Gi1/2 1 0/0 1 0/10 50 0
Gi1/3 1 0/0 6 0/10 50 0
Gi1/7 1 0/0 1 0/10 50 0
Gi1/8 0 0/0 0 0/10 0 0
Gi2/1 1 0/0 3 0/10 50 0
Gi2/2 1 0/0 1 0/10 50 0
Gi2/3 1 0/0 1 0/10 50 0
Gi2/4 2 0/0 0 0/10 50 4
Gi2/5 0 0/0 0 0/10 0 0
Gi2/9 2 0/0 1 0/10 50 0
Gi2/13 0 0/0 0 0/10 0 0
Gi2/24 0 0/0 0 0/10 0 0
Gi2/48 1 0/0 1 0/10 50 0
Gi2/11 0 0/0 0 0/10 0 0
Routing Protocol is "eigrp 2146"
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
Default networks flagged in outgoing updates
Default networks accepted from incoming updates
EIGRP metric weight K1=1, K2=0, K3=1, K4=0, K5=0
EIGRP maximum hopcount 100
EIGRP maximum metric variance 1
Redistributing: connected, static, eigrp 2146
Automatic network summarization is not in effect
Maximum path: 4
Routing for Networks:
10.0.0.0
192.168.225.0
192.168.231.0
192.168.233.0
192.168.244.0
192.168.247.0
192.168.248.0
Passive Interface(s):
Vlan1
Routing Information Sources:
Gateway Distance Last Update
10.149.172.2 90 00:00:00
10.149.168.2 90 00:00:01
10.149.164.2 90 00:00:01
10.149.212.2 90 00:00:01
10.149.208.2 90 00:00:01
10.149.224.5 90 01:12:07
10.149.224.2 90 04:03:47
10.128.8.1 90 00:00:01
10.135.24.1 90 00:00:01
10.128.16.1 90 00:00:01
10.129.112.2 90 00:00:01
10.129.112.4 90 00:00:01
Distance: internal 90 external 170
jorgecorrales1
Community Member
2800
Fa0/0 0 0/0 0 0/10 0 0
Fa0/1 2 0/0 0 0/10 50 4
Se0/0/0 1 0/0 1 0/11 50 0
Se0/1/0 1 0/0 8 0/11 50 0
Se0/1/1 1 0/0 9 0/11 50 0
Se0/2/0 1 0/0 1 0/15 50 0
Se0/3/0 0 0/0 0 5/10 0 0
EIGRP NSF-aware route hold timer is 240s
Address Summarization:
0.0.0.0/0 for Serial0/1/0
Summarizing with metric 28160
Maximum path: 4
10.0.0.0
(this router) 90 01:12:53
10.133.168.2 90 00:01:15
10.133.164.2 90 00:01:15
10.129.164.1 90 00:01:14
10.133.176.2 90 00:01:15
10.149.224.5 90 01:11:39
10.149.224.1 90 04:03:57
Routing Protocol is "rip"
Sending updates every 30 seconds, next due in 26 seconds
Invalid after 180 seconds, hold down 180, flushed after 240
Redistributing: rip
Default version control: send version 2, receive version 2
Interface Send Recv Triggered RIP Key-chain
FastEthernet0/0 2 2
FastEthernet0/1 2 2
Serial0/0/0 2 2
Serial0/1/0 2 2
Serial0/1/1 2 2
Serial0/2/0 2 2
Serial0/3/0 2 2
Automatic network summarization is in effect
Maximum path: 4
10.0.0.0
Distance: (default is 120)
1600
BR0 0 0/0 0 10/10 0 0
Et0 0 0/0 0 0/10 50 0
Se0 1 0/0 6 0/11 50 0
Automatic address summarization:
192.168.249.0/24 for BRI0, Ethernet0, Serial0
192.168.249.0
10.0.0.0
10.133.164.1 90 00:00:13
10.149.224.2 90 04:04:47
10.149.224.1 90 01:10:09
You have summarization enabled on the 1600. Please disable it with the no auto-summary command under the EIGRP process.
I just disabled it as you advice, but neighborhood doesn't establish yet.
Can we see the 1600's config ?
Here is it. I just deleted password information.
Current configuration:
! Last configuration change at 18:32:04 UTC Mon Jul 23 2007
! NVRAM config last updated at 18:32:35 UTC Mon Jul 23 2007
version 11.2
service password-encryption
no service udp-small-servers
no service tcp-small-servers
hostname ROT-AGN01-CAR
enable secret 5
username sanjose password 7
username ROT-AGN01-CAR password 7
ip domain-name ice.go.cr
ip name-server 10.129.20.21
isdn switch-type basic-net3
interface Ethernet0
description ROT-AGN01-CAR-LAN-ETH000
ip address 10.133.8.1 255.255.252.0 secondary
ip address 10.149.224.5 255.255.252.0
interface Serial0
description ROT-AGN01-CAR-CTLCAR-SER000
backup delay 0 0
backup interface BRI0
ip address 10.133.164.2 255.255.252.0
bandwidth 2048
no fair-queue
interface BRI0
description ROT-AGN01-CAR-SJO-BRI000
ip address 10.131.196.23 255.255.252.0
encapsulation ppp
dialer map ip 10.131.196.1 name sanjose broadcast 2589480
dialer-group 1
no fair-queue
ppp multilink
router eigrp 2146
redistribute connected
redistribute static
network 192.168.249.0
network 10.0.0.0
no auto-summary
eigrp log-neighbor-changes
ip classless
ip route 0.0.0.0 0.0.0.0 10.133.164.1
logging buffered 10000 debugging
snmp-server community RW
snmp-server community RO
snmp-server trap-authentication
snmp-server host 10.129.20.74 snmp
dialer-list 1 protocol ip permit
banner motd ^Ctod
* ROUTER AGENCIA CARTAGO *
* I . C . E . T . E . L *
* INFRAESTRUCTURA DE CONECTIVIDAD *
* D . A . T . I *
^C
line con 0
password 7
login
line vty 0 4
password 7
login
ntp clock-period 17042050
ntp server 10.149.164.2
end
jorgecorrales1
Community Member
This is "sh version" output, maybe it would be helpful.
IOS (tm) 1600 Software (C1600-NSY-L), Version 11.2(11)P, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1998 by cisco Systems, Inc.
Compiled Tue 06-Jan-98 05:52 by dschwart
Image text-base: 0x080254D4, data-base: 0x02005000
ROM: System Bootstrap, Version 11.1(10)AA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc
1)
ROM: 1600 Software (C1600-BOOT-R), Version 11.1(10)AA, EARLY DEPLOYMENT RELEASE
SOFTWARE (fc1)
ROT-AGN01-CAR uptime is 1 week, 2 hours, 5 minutes
System restarted by power-on at 19:57:17 UTC Mon Jul 16 2007
System image file is "flash:c1600-nsy-l.112-11.P", booted via flash
cisco 1603 (68360) processor (revision C) with 3584K/512K bytes of memory.
Processor board ID 07856241, with hardware revision 00000000
Bridging software.
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
Basic Rate ISDN software, Version 1.0.
1 Ethernet/IEEE 802.3 interface(s)
1 serial(sync/async) network interface(s)
1 ISDN Basic Rate interface(s)
System/IO memory with parity disabled
2048K bytes of DRAM onboard 2048K bytes of DRAM on SIMM
System running from FLASH
8K bytes of non-volatile configuration memory.
8192K bytes of processor board PCMCIA flash (Read ONLY)
You have a 1998 IOS release running there, very old and I wonder if that's the problem here.
Is it possible to upgrade the IOS on this router ?
Can I see the show run from the 2800 router ?
