10-06-2020 01:51 PM
i've configured this easily on a cat9300 connected to an isr1000 but i'm having issues getting it to work between a 2960cx and isr1841. i can ping across the native vlan but not any of the others. i'm not sure if the old 1841 needs some extra stuff setup that we take for granted in the new platforms? the 1841 is running 12.4(17)
SWITCH CONFIG
interface GigabitEthernet0/2
switchport trunk native vlan 62
switchport mode trunk
end
Vlan5 10.89.5.130 YES NVRAM up up
Vlan62 10.89.62.244 YES DHCP up up
ROUTER CONFIG
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.5
encapsulation dot1Q 5
ip address 10.89.5.129 255.255.255.192
interface FastEthernet0/0.62
encapsulation dot1Q 62 native
ip address 10.89.62.1 255.255.255.0
ip helper-address 10.224.109.35
ip helper-address 10.224.209.25
Solved! Go to Solution.
10-10-2020 10:54 AM
Glad that you found that post explaining that attempting to send an IP packet when there is no arp entry for the next hop mac address will result in encapsulation failure. So the question becomes why is arp failing?
The show commands from both devices indicate that both devices see it as dot1q encapsulation. But the fact that it seems that no traffic actually goes through the tagged vlan makes me wonder if one of the devices is really having problems with it. I wonder if we might get any insight if you do this on both devices:
- make sure that the logging level is set to debug
- show cdp neighbor detail
- shut the interface
- no shut the interface
- attempt to ping the neighbor address
- post any output
10-06-2020 02:06 PM
post the full configs of both the switch and the router. If your goal is to configure a router-on-a-stick, your switch cannot have Vlan interfaces other than the native Vlan.
10-06-2020 02:10 PM
Try on the switch side and test and advise. ( by default your config should work)
switchport trunk allowed vlan 5,62 ( add any other vlan to pass)
end
still an issue post complete configuration of all devices which was part.
=====️ Preenayamo Vasudevam ️=====
10-06-2020 02:23 PM
This is off topic a bit, but I think there is something wrong with the rating system. I sometimes get a 'Helpful' vote right after I post an answer, not from the OP, but from a user who has never contributed to anything in the past. The vote comes faster than anybody can possibly read the answer, so it looks like some sort of automated procedure...
Has anybody experienced this as well here on this forum ?
10-06-2020 11:35 PM
Hello Georg,
yes I have the same impression sometimes I have got rating for a post just inserted in the forum from someone that is not the original poster.
Best Regards
Giuseppe
10-07-2020 12:32 AM
In this day and age, the first thing that comes to mind is that these are hack attempts. Although I wonder what they would want to hack. I'll send a message to Monica, maybe she can look into it.
10-07-2020 06:53 AM
It might be helpful if, in addition to the complete configs, we got the output of these commands on both devices
show ip interface brief
show ip route
show arp
10-07-2020 08:27 AM
the switch trunk already has switchport trunk allowed vlan all
the intent is not a router on a stick. this device is currently using a management ip on our user vlan. the goal is to use a management ip on vlan 5. the switch must still pass vlan 62 user traffic though. i need to prove vlan 5 and 62 are both properly passing traffic over the link before i change the default route, delete svi for vlan62, and mark both vlans as tagged, neither will be native. with a cat9300 connected to isr1000 i was able to easily do this, multiple svis and subinterfaces all capable of passing ping. this should be stupid simple but i've spent more than half my day on it.
there are no users at the site right now (covid wfh) so i don't have any users to test the user vlan after change. the device is also remote so i'm trying not to orphan it but the good news there are no users at the site so i can always recover using config archive or 'reboot in'.
sanitized configs attached. there really isn't anything relevant in them beyond what was posted. show commands are also in the files. you can see the arp doesn't even resolve over vlan5
10-07-2020 10:03 AM
also this is interesting. i'm not sure what 'other' vs IP traffic is. it doesn't show any ip traffic for vlan 5 on the router
USCPV1-F1-IR-01#show vlans
Virtual LAN ID: 1 (IEEE 802.1Q Encapsulation)
vLAN Trunk Interface: FastEthernet0/0
Protocols Configured: Address: Received: Transmitted:
Other 0 9829
0 packets, 0 bytes input
9829 packets, 718250 bytes output
Virtual LAN ID: 5 (IEEE 802.1Q Encapsulation)
vLAN Trunk Interface: FastEthernet0/0.5
IP 10.89.5.129 0 0
Other 0 29
29 packets, 1683 bytes output
Virtual LAN ID: 62 (IEEE 802.1Q Encapsulation)
vLAN Trunk Interface: FastEthernet0/0.62
This is configured as native Vlan for the following interface(s) :
FastEthernet0/0
IP 10.89.62.1 408853 418417
Other 0 5965
416085 packets, 122688079 bytes input
424382 packets, 203588282 bytes output
on the switch it shows outgoing from my ping attempts
USCPV1-F1-AS-01#show int vlan5
Vlan5 is up, line protocol is up
Hardware is EtherSVI, address is 0cd0.f8ca.4b41 (bia 0cd0.f8ca.4b41)
Internet address is 10.89.5.130/26
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not supported
Last input never, output 01:57:55, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
13 packets output, 895 bytes, 0 underruns
0 output errors, 3 interface resets
0 unknown protocol drops
10-07-2020 10:37 AM
Thanks for the additional information. Not sure about the "other" traffic, but several possibilities come to mind:
- perhaps it is trunk negotiation frames
- perhaps it is spanning tree frames
I do not see any obvious issues in the posted configs that would explain why vlan5 is not working. I note that ip routing is enabled on the switch so both vlans should be able to operate at the same time. But something is not right. Would you post the output of these commands on the switch:
show interface status
show interface trunk
10-07-2020 10:45 AM
USCPV1-F1-AS-01#show int status
Port Name Status Vlan Duplex Speed Type
Gi0/1 notconnect 62 auto auto 10/100/1000BaseTX
Gi0/2 USCPV1-F1-IR-01 connected trunk a-full a-100 10/100/1000BaseTX
Gi0/3 notconnect 62 auto auto 10/100/1000BaseTX
Gi0/4 notconnect 62 auto auto 10/100/1000BaseTX
Gi0/5 notconnect 62 auto auto 10/100/1000BaseTX
Gi0/6 notconnect 62 auto auto 10/100/1000BaseTX
Gi0/7 notconnect 62 auto auto 10/100/1000BaseTX
Gi0/8 notconnect 62 auto auto 10/100/1000BaseTX
Gi0/9 notconnect 62 auto auto 10/100/1000BaseTX
Gi0/10 notconnect 62 auto auto 10/100/1000BaseTX
Gi0/11 notconnect 62 auto auto Not Present
Gi0/12 notconnect 62 auto auto Not Present
USCPV1-F1-AS-01#show int trunk
Port Mode Encapsulation Status Native vlan
Gi0/2 on 802.1q trunking 62
Port Vlans allowed on trunk
Gi0/2 1-4094
Port Vlans allowed and active in management domain
Gi0/2 1,5,62
Port Vlans in spanning tree forwarding state and not pruned
Gi0/2 1,5,62
10-07-2020 11:51 AM
Thanks for the additional output. From what we are seeing I would expect it to work. But it is not working. would you configure one of the switch interfaces to be an access port in vlan 5 and see if that makes any difference.
10-07-2020 12:07 PM
still no go. very puzzling. i was really hoping someone on here was going to be like 'oh, on those old routers you also have to do blah blah blah...'
i did try going into vlan database mode and create the vlans but that didn't help. at one point i also created a subinterface that was tied to a bridge group and then configured a bvi interface but that didn't work. despite ip routing being enabled on the switch i did try shutting 62 down to see if 5 worked then but it does not, so long as it is set as tagged. i can only get whatever vlan is set as native to work
10-07-2020 12:41 PM
can you post show interface for router main int and subinerfaces
10-07-2020 12:50 PM
USCPV1-F1-IR-01#show int fa0/0
FastEthernet0/0 is up, line protocol is up
Hardware is Gt96k FE, address is 0014.f2a9.4b46 (bia 0014.f2a9.4b46)
Description: Cape Canaveral MOCC LAN
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:24, output 00:00:00, output hang never
Last clearing of "show interface" counters 1d01h
5 minute input rate 23000 bits/sec, 19 packets/sec
5 minute output rate 24000 bits/sec, 19 packets/sec
471269 packets input, 139857365 bytes
Received 8364 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
493916 packets output, 228346204 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
461621 unknown protocol drops
0 lost carrier, 0 no carrier
USCPV1-F1-IR-01#show int fa0/0.5
FastEthernet0/0.5 is up, line protocol is up
Internet address is 10.89.5.129/26
Encapsulation 802.1Q Virtual LAN, Vlan ID 5.
USCPV1-F1-IR-01#show int fa0/0.62
FastEthernet0/0.62 is up, line protocol is up
Internet address is 10.89.62.1/24
Encapsulation 802.1Q Virtual LAN, Vlan ID 62.
