Two Subnets One Interface
kevenpenner
Community Member
Hi guys,
I have two public subnets one a /28 and a /29. They come to me on one ethernet cable from the ISP. Currently I have the ethernet cable plugged into a switch and have two 1700's running each network. I have two seperate private networks NAT'ed behind each router.
I want to use a single 1841 router to do the same thing if possible. I have added all the IP addresses to FE0/0 using the secondary command, I added both Private networks the same way to FE0/1 (192.168.0.1, 192.168.1.1 secondary). Nated the interfaces and set permit access list for both private network ranges to be nat'ed.
I am wondering what else I need to do or is it as simple as that? Do I add two IP routes? ie
0.0.0.0 0.0.0.0 Network1.Gateway.IP
0.0.0.0 0.0.0.0 Network2.Gateway.IP
Please let me know if you need more info. And thanks in advance!
K
Edison Ortiz
kevenpenner wrote:
Hi guys,
K
If the ISP is providing a single handoff and they aren't 802.1q tagged, it means they configured the primary/secondary on their router end. Matching their setup with a single router it is possible. As far as the default route, just point the default to the primary next hop IP address as the packet will go to the same physical router.
If you create Vlans as recommended before, it may not work as you would send tagged traffic to the connected router and this configuration would need to match in both ends.
Consult your ISP and ask them how they are configured.
Edison
8 Replies 8
RAMACHANDRA R
Level 3
Level 3
Instead of going secondary ip address for ISP and Local LAN you can have sub interface with diffrent vlan for the same ( provided the switch sholud support VLAN configuration/manegable switch).
You need to have policy routing to send your traffic out on Indivdual ISP based on /28 and /29 subnet to ensure that you or not doing asymmterical routing and ending up loosing both the internet when one ISP goes down.
Rgds
Rama
Thanks for the reply. My switch is a managed layer 3 supporting vlans. I dont actually need both the private netoworks; I could combined them into one if that would be easier. Also it's the same ISP so if one subnet goes down they both would anyway.
Is vlan still a better way to go on the outside ip blocks?
ISP block 1
ISP block 2
  1841 FE0/0
  1841 FE0/1
Nat'ed local LAN
(Have servers using both blocks of IP's)
Edison Ortiz
kevenpenner wrote:
Hi guys,
K
Edison
Thanks guys for all your help.
So it all worked except for one thing. I cant route between the two public subnets. Is there an easy fix?
ie.
MailServer01 on 192.168.0.1 sends out through 209.143.23.2 --->
209.143.36.4 incomming to MailServer02 192.168.1.1
209.143.23.2
209.143.35.4 secondary
  1841 FE0/0
  1841 FE0/1
Nat'ed local LAN
192.168.0.254 /24
192.168.1.254 /24
Switch with both MailServers plugged in.
If I used sub interfaces like Rama suggested would that allow for traffic to leave one private network and arrive on the other?
We assume that  accessing both mail server on local subnet working ie 192.168.0.1 to 192.168.1.1 and vice versa, but you are not able to  reach mail servers on their nated public ip address from the server 192.168.0.1 to 209.143.36.4. and 192.168.1.1 to 209.143.23.2 .
are you doing port forwarding on router ? can you post nat config for us to analyze.
Rgds
Rama
yes they are nated and port forwarded.
Current configuration : 9866 bytes
version 12.4
service password-encryption
hostname Router
boot-start-marker
boot system flash c1841-adventerprisek9-mz.124-25e.bin
boot-end-marker
enable password 7 xxxxxxxx
no aaa new-model
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username xxxxx privilege 15 password 7 xxxxxxxxxxxx
archive
path flash:
maximum 2
interface FastEthernet0/0
ip address 209.143.35.4 255.255.255.240 secondary
ip address 209.143.23.2 255.255.255.248
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.0.254 255.255.255.0 secondary
ip address 192.168.1.254 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
no fair-queue
interface BRI0/1/0
no ip address
encapsulation hdlc
shutdown
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.0.254 25 209.143.23.2 25 extendable
ip nat inside source static tcp 192.168.1.254 25 209.143.35.4 25 extendable
Please let meknow if you need more info.
