Web interface is slow
SCOTT No2
Visitor
Recently, when I log into my switches (SG350X-48), the webpage is super slow to load.  it shows "processing data 60%".   then sometimes it stops. sometimes it doesn't finish.  sometimes it does load but the graphics (links to pictures) are missing.
I have a few of the SG350x-48s in 3 separate stacks.  Each stack seems to do the same slow-load.  I thought it was my browser (Firefox) but it happens on other browsers.  Also this browser is set to delete cache and cookies at close.
What can I do to speed this up? or is this just how it is?  Reboot (which takes down the network)?  Any general thoughts?
Thanks.
balaji.bandi
Login SSH and check the logs, most of the suggestion reboot (in the maintenance window)
BB
balaji.bandi
BB
SCOTT No2
Visitor
Thank you for your response.  (This is going to be a bad question)  How do I reboot the switch?  The original engineer left and i took over; I'm trying to learn how to run these switches.  thanks.
ssh to device and issue
#reload
BB
