11-18-2014 01:49 AM - edited 03-05-2019 12:11 AM
I currently have a router that has 2 circuits (Circuit 1 and Circuit 2) from 1 provider. Circuit 1 is set up for a DMVPN Hub and Circuit 2 is set up for internet traffic.
I have been asked to add 1 additional circuit (Circuit 3) from a different provider and loadbalance DMVPN over Circuit 1 and Circuit 3....is this possible?
I obviously cant use multiple tunnel source ip under the tunnel but can i use 2 tunnel interface which would then give me 2 DMVPN hubs on a single router?
What are the issues that I have to watch out for...Asymetric routing maybe?
Any advice? Link to how to do articles? anything that can help me accomplish this.
Thank you,
Solved! Go to Solution.
11-18-2014 11:55 PM
Both Tunnel should run Eigrp in Global Routing table in HUB. Tunnel VRF used to specify which routing table to look for Tunnel Source and Tunnel Destination. It does not put Tunnel Interface itself into VRF. The only routing in VRF is static default route
ip route vrf Circuit1 0.0.0.0 0.0.0.0 "WAN 1 next hop IP"
ip route vrf Circuit3 0.0.0.0 0.0.0.0 "WAN 3 next hop IP"
Then You cloud configure Un-Equal cost load balancing using Eigrp once neighbour relationship formed.
Pls rate useful post
11-18-2014 05:47 AM
There are many things need to be considered.
1) 1st & 3rd circuit will be used for internet browsing ? If not, then it would more easier to achieve your goal.
You would need to put 1st Circuit & 3rd Circuit in different VRF
1) ip vrf Circuit1
2) ip vrf Circuit3
Put both circuit in respective VRF
Interface fastethernet0/0
description *** Circuit 1***
ip vrf forwarding Circuit1
ip add a.a.a.a y.y.y.y
Interface fastethernet0/1
description *** Circuit 3***
ip vrf forwarding Circuit3
ip add b.b.b.b y.y.y.y
You should have default route for both VRF. To confirm if VRF configured properly, make sure you able reach your Circuit 1 & 3 WAN IP from Internet.
Then you would need too have two DMVPN Tunnel
First Tunnel uses Tunnel Source Fa0/0 and need to specify Tunnel VRF. Tunnel VRF command tells the Router to look in specific vrf routing for Source IP and Destination IP(Spoke IP). The method apply for second DMVPN tunnel.
Int Tunnel0
description *** DMVPN 1***
tunnel vrf Circuit1
tunnel source fa0/0
Int Tunnel1
tunnel vrf Circuit3
tunnel source fa0/1
Now that its better to protect the tunnel with IPSec Profile.
crypto keyring Circuit1-Keyring vrf Circuit1
pre-shared-key address 0.0.0.0 key Key@VPN
crypto keyring Circuit3-Keyring vrf Circuit3
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto ipsec transform-set VTI esp-3des esp-md5-hmac
mode transport
crypto ipsec profile VTI-Profile
set transform-set VTI
Int Tun0
tunnel protection ipsec profile VTI-Profile
Int Tun1
Important Note : Make sure your DMVPN tunnel uses different NHRP network id
Int tun0
ip nhrp network-id 111
Int tun0
ip nhrp network-id 112
11-18-2014 05:47 AM
11-18-2014 06:15 AM
You need to use VRF in HUB site, otherwise only one DMVPN tunnel can pick-up at given time. because of default route. You can add two default route ( each via Circuit 1 & 3) , but Remember that, traffic always 2 ways, Spoke could point to Circuit 1 WAN IP , but might return via Circuit 3 which end up causing Tunnel cant pick up. VRF can solve this problem. On branch you dont need VRF, as only 1 circuit available for all purpose.
The above config just to bring up both DMVPN tunnel. We haven't talk about load balancing. PBR could be very troublesome, as you would need to apply it at both site (HUB and SPOKE) to make traffic path synchronous. Another viable solution is you could actually do NAT on SPOKE router. NAT user IP to Tunnel IP . As such, you would only need to specify PBR at SPOKE level and the return traffic will get on same path.
11-18-2014 10:10 PM
do you mean:
Int Tunnel0
tunnel vrf Circuit1
tunnel source fa0/0
Int Tunnel1
description *** DMVPN 2***
tunnel vrf Circuit3
tunnel source fa0/3
question:
based on your response, please confirm that my understanding of VRF-lite is correct. I am new to VRF!
On the Hub:
VRF 1 (Tunnel 0) points to WAN 1
NOVRF points to WAN 2
VRF 3 (Tunnel 1) points to WAN 3
There are 3 LAN interfaces.
LAN 1
LAN 2
LAN3
Routint table:
VRF 1 routing table: runs EIGRP with the Tunnel 0 subnet
used for DMVPN and VOIP Traffic
Global routing table: runs EIGRP with LAN1, LAN2, LAN3
used for Internet, SSL VPN, and Portforwarding to Servers.
VRF 3 routing table: runs EIGRP with the Tunnel 1 subnet
On the Spokes,
Tunnel 0 and Tunnel 1 registers to their respective DMNPN Server or HUB but through a shard public interface.
EIGRP is used for load balancing
NOW, being that LAN1, LAN2 and LAN3 are only on the Global routing table at the HUB, how will the traffic from the remote site that traverses the DMVPN tunnel talk to LAN1, LAN2, and LAN3?
Would I have to use MP-BGP to communicate between the three route instances....and if so, is there s possibility for Asymmetric routing?
Thank you,
David
11-18-2014 11:55 PM
11-19-2014 04:43 AM
Light bulb! I cant take credit for this...it was all you. Its brilliant!
Thank you,
12-22-2014 07:10 AM
what if I chose not to use VRFs?...could i use a static route on the hub to each site instead of the default route? All current sites and all future sites will have a static IP so I wont really need to have more than one default route on the hub. using the VRF broke email for me because i couldnt communicate between one of the public WAN IP's and my local subnet. I know I could do inter VRF routing but I am not to familiar with that.
