100% CPU Usage on 887VA when network traffic is heavy
Ian Stephens
We have a problem with 100% CPU usage and a small packet loss when the router can't keep up at full speed (100Mb/s) NAT.
We are not using any inspect commands, so there are no overheads there.
Why is the router slowing down and grinding to a halt?
We are running a basic NAT and our ISP has provided us 100Mb/s VDSL connection.  It's when we hit these high speeds that the router CPU usage hits 100% and we experience packet loss when pinging for example (intermittent no replies... etc).
Below is our running config and process information.
Your thoughts, fixes, comments and suggestions are greatly appreciated.
show proc cpu sort
r1.xxx.xxxx.com#show proc cpu sort
CPU utilization for five seconds: 96%/96%; one minute: 96%; five minutes: 96%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
  98      340532    13421485         25  1.89%  1.28%  1.21%   0 Ethernet Msec Ti
   2       35928       21401       1678  1.34%  1.04%  1.03%   0 Load Meter
  92     2372784      528420       4490  0.63%  0.83%  0.96%   0 COLLECT STAT COU
146        1192       16749         71  0.47%  0.06%  0.01%   0 TCP Timer
289       93284     3293892         28  0.39%  0.25%  0.24%   0 PPP Events
281       18392      828131         22  0.23%  0.07%  0.06%   0 PPPoE Background
115      156872      146421       1071  0.23%  0.19%  0.15%   0 IP Input
288      134128     3293930         40  0.23%  0.41%  0.42%   0 PPP manager
  97       23132      775596         29  0.15%  0.06%  0.07%   0 Ethernet Timer C
111       74836     3279452         22  0.15%  0.24%  0.23%   0 IPAM Manager
  63       69968      555090        126  0.15%  0.23%  0.23%   0 LED Timers
283       17560      209076         83  0.07%  0.03%  0.05%   0 IP NAT Ager
274        7452       21461        347  0.07%  0.03%  0.00%   0 Compute load avg
188        7740      207739         37  0.07%  0.02%  0.00%   0 Inspect process
  68        4680      106699         43  0.07%  0.01%  0.00%   0 Console redirect
  32        7896      111262         70  0.07%  0.03%  0.00%   0 ARP Background
  17        4212      104127         40  0.07%  0.02%  0.00%   0 IPC Periodic Tim
  25        1380       21372         64  0.07%  0.00%  0.00%   0 IPC Loadometer
  56        6512       54449        119  0.07%  0.02%  0.00%   0 Fast Throttle Ti
244        2860         189      15132  0.07%  0.14%  0.03%   8 Virtual Exec
AND MORE... but I omitted it because I was getting the message "This message can not be displayed due to its content. Please use the Contact Us link with any questions"...
Our Running Config
version 15.1
no service pad
hostname r1.essex.xxxx.xxx
boot-start-marker
boot system flash c880data-universalk9-mz.151-4.M3.bin
boot-end-marker
no logging buffered
enable secret 5 xxxxxx
enable password xxxxxx
no aaa new-model
memory-size iomem 10
no ip source-route
ip dhcp excluded-address 192.168.0.1
ip dhcp excluded-address 192.168.0.50 192.168.0.255
ip dhcp pool NET-POOL
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 8.8.8.8 8.8.4.4
ip cef
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
controller VDSL 0
no ip ftp passive
interface Ethernet0
no ip address
interface Ethernet0.101
encapsulation dot1Q 101
pppoe-client dial-pool-number 1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
shutdown
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
no ip address
shutdown
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Dialer0
ip address 81.138.131.190 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname xxxxxxxx
ppp chap password 0 xxxxxxxxx
ppp ipcp route default
no cdp enable
ip forward-protocol nd
no ip http server
ip http secure-server
ip nat inside source list 101 interface Dialer0 overload
ip nat inside source static 192.168.0.250 xxx.xxx.xxx.xxx
access-list 101 permit ip any any
21 Replies 21
Please bear in mind that I currently have virtual-reassembly disabled on both interfaces, however here is the output:
Dialer0:
   Virtual Fragment Reassembly (VFR) is DISABLED [in]
   Concurrent reassemblies (max-reassemblies): 16
   Fragments per reassembly (max-fragments): 32
   Reassembly timeout (timeout): 3 seconds
   Drop fragments: OFF
   Current reassembly count:0
   Current fragment count:0
   Total reassembly count:1334
   Total reassembly timeout count:93
Vlan1:
   Drop fragments: OFF
   Total reassembly count:2
   Total reassembly timeout count:0
Does this look normal?  I can enable virtual-reassembly again and max out the router to see what happens?  Thank you for yout time.
I presume that the counters of virtual-reassembly can not be cleared (need a reload of router / or maybe shut-no shut of the interfaces).
But as already indicated by JosephDoherty
Your configuration looks pretty "clean", so your only real solution would be a "faster" device.
can you indicate when the CPU rise to 100% ? when the throughput is .... Mbps
how you verify the throughput ?
can you paste the sh tech ? or send me by email ?
Hey Roberto,
The CPU hits the 100% mark when we are pushing around 90Mb/s inbound from the Dialer0 to the Vlan1 (downloading a file for example).  There are not many NAT clients behind the network yet, so it's purely throughput not bloating of the NAT translation table.  I think even when we hit 100% CPU, the translation table only has 100 entries.
I'll private message you the output of sh tech now!
Thank you for your help!
Best Regards,
Ryan
That is normal, and consistent or exceeding the performances tested by Cisco. See attachment, NAT testing.
With such a fast circuit, you will need a faster router.
Hey Roberto,
I have private messaged you with regards to the output of "sh tech".  It's far too large to paste into the message box, it just makes all of my browsers hang.
I initially asked for your email address, but I have just uploaded it to one of our servers so you can view it directly from there.
I have private messaged you the link.
Thank you for your help Roberto.
Ok
