100% CPU Usage on 887VA when network traffic is heavy
Ian Stephens
We have a problem with 100% CPU usage and a small packet loss when the router can't keep up at full speed (100Mb/s) NAT.
We are not using any inspect commands, so there are no overheads there.
Why is the router slowing down and grinding to a halt?
We are running a basic NAT and our ISP has provided us 100Mb/s VDSL connection.  It's when we hit these high speeds that the router CPU usage hits 100% and we experience packet loss when pinging for example (intermittent no replies... etc).
Below is our running config and process information.
Your thoughts, fixes, comments and suggestions are greatly appreciated.
show proc cpu sort
r1.xxx.xxxx.com#show proc cpu sort
CPU utilization for five seconds: 96%/96%; one minute: 96%; five minutes: 96%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
  98      340532    13421485         25  1.89%  1.28%  1.21%   0 Ethernet Msec Ti
   2       35928       21401       1678  1.34%  1.04%  1.03%   0 Load Meter
  92     2372784      528420       4490  0.63%  0.83%  0.96%   0 COLLECT STAT COU
146        1192       16749         71  0.47%  0.06%  0.01%   0 TCP Timer
289       93284     3293892         28  0.39%  0.25%  0.24%   0 PPP Events
281       18392      828131         22  0.23%  0.07%  0.06%   0 PPPoE Background
115      156872      146421       1071  0.23%  0.19%  0.15%   0 IP Input
288      134128     3293930         40  0.23%  0.41%  0.42%   0 PPP manager
  97       23132      775596         29  0.15%  0.06%  0.07%   0 Ethernet Timer C
111       74836     3279452         22  0.15%  0.24%  0.23%   0 IPAM Manager
  63       69968      555090        126  0.15%  0.23%  0.23%   0 LED Timers
283       17560      209076         83  0.07%  0.03%  0.05%   0 IP NAT Ager
274        7452       21461        347  0.07%  0.03%  0.00%   0 Compute load avg
188        7740      207739         37  0.07%  0.02%  0.00%   0 Inspect process
  68        4680      106699         43  0.07%  0.01%  0.00%   0 Console redirect
  32        7896      111262         70  0.07%  0.03%  0.00%   0 ARP Background
  17        4212      104127         40  0.07%  0.02%  0.00%   0 IPC Periodic Tim
  25        1380       21372         64  0.07%  0.00%  0.00%   0 IPC Loadometer
  56        6512       54449        119  0.07%  0.02%  0.00%   0 Fast Throttle Ti
244        2860         189      15132  0.07%  0.14%  0.03%   8 Virtual Exec
AND MORE... but I omitted it because I was getting the message "This message can not be displayed due to its content. Please use the Contact Us link with any questions"...
Our Running Config
version 15.1
no service pad
hostname r1.essex.xxxx.xxx
boot-start-marker
boot system flash c880data-universalk9-mz.151-4.M3.bin
boot-end-marker
no logging buffered
enable secret 5 xxxxxx
enable password xxxxxx
no aaa new-model
memory-size iomem 10
no ip source-route
ip dhcp excluded-address 192.168.0.1
ip dhcp excluded-address 192.168.0.50 192.168.0.255
ip dhcp pool NET-POOL
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 8.8.8.8 8.8.4.4
ip cef
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
controller VDSL 0
no ip ftp passive
interface Ethernet0
no ip address
interface Ethernet0.101
encapsulation dot1Q 101
pppoe-client dial-pool-number 1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
shutdown
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
no ip address
shutdown
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Dialer0
ip address 81.138.131.190 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname xxxxxxxx
ppp chap password 0 xxxxxxxxx
ppp ipcp route default
no cdp enable
ip forward-protocol nd
no ip http server
ip http secure-server
ip nat inside source list 101 interface Dialer0 overload
ip nat inside source static 192.168.0.250 xxx.xxx.xxx.xxx
access-list 101 permit ip any any
2 Accepted Solutions
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
"Software" based routers use their main CPU for everything including forwarding packets.  When you push enough traffic toward them, their CPU will max out, which seems to be your case from both your CPU stats and the volume of traffic you describe.  An 880 series router is rated at 50 Kpps or about 25 Mbps (unidirectional).  That's for minimal sized packet so higher throughput is possible with larger packets (often the norm).  Cisco notes max transfer rate (for 1500 byte packets) at about 200 Mbps.  They also recommend the 880 for WAN links up to 8 Mbps (duplex).
Your configuration looks pretty "clean", so your only real solution would be a "faster" device.
The CPU hits the 100% mark when we are pushing around 90Mb/s inbound from the Dialer0 to the Vlan1 (downloading a file for example).  There are not many NAT clients behind the network yet, so it's purely throughput not bloating of the NAT translation table.  I think even when we hit 100% CPU, the translation table only has 100 entries.
That is normal, and consistent or exceeding the performances tested by Cisco. See attachment, NAT testing.
With such a fast circuit, you will need a faster router.
21 Replies 21
Joseph W. Doherty
Disclaimer
Posting
Thank you for your reply Josepth.
That's what I thought too - I thought we had reached the limit of what the router could handle.
However, dropping packets is a bit of an issue, I didn't expect that.  Are there any tweaks we could put in place to stop packet loss?
Thanks again.
Disclaimer
Posting
Yes and no.  As your configuration is "clean", you've not "wasting" CPU.
What you could consider, ingress shapers to selectively drop some traffic.  Right now your drops are "random", but if you're going to have drops, one could argue it's better to be selective about them.  For example, you might drop packets from TCP flows, which will both recover from the drops and slow their transmission rate.  This would help preclude drops from traffic that doesn't deal well with packet loss.
Of course, this does add additional load to your processing, so your overall throughput is likely to be even less, yet it might seem better to your users.
Also, I forgot to mention Joseph - when we disable CEF, traffic slows right down to just 20Mb/s - that's all we can push through it.  However, with CEF enabled we can push almost 100Mb/s - is this normal?
Disclaimer
Posting
Can't say whether that much of a delta is normal, but CEF is Cisco's premiere technology, designed to increase L3 forwarding performance.  So a drop in forwarding performance should be expected, again though, just the delta is the open issue (NB: your mileage may vary).
Thanks for the information Joseph.  I have just looked at our Dialer interface and noticed that "Stateful Inspection" is present:
Dialer0 is up (if_number 12)
  Corresponding hwidb fast_if_number 12
  Corresponding hwidb firstsw->if_number 12
  Internet address is xxx.xxx.xxx.xxx/29
  ICMP redirects are never sent
  Per packet load-sharing is disabled
  IP unicast RPF check is disabled
  Input features: Stateful Inspection, Dialer i/f override, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, NAT Outside
  Output features: Post-routing NAT Outside, Stateful Inspection, Dialer idle reset, Dialer idle reset
  IP policy routing is disabled
  BGP based policy accounting on input is disabled
  BGP based policy accounting on output is disabled
  Interface is marked as point to point interface
  Hardware idb is Dialer0
  Fast switching type 15, interface type 98
  IP CEF switching enabled
  IP CEF switching turbo vector
  IP Null turbo vector
  IP prefix lookup IPv4 mtrie 8-8-8-8 optimized
  Input fast flags 0x400040, Output fast flags 0x10100
  ifindex 12(12)
  Slot  Slot unit -1 VC -1
  IP MTU 1492
Is this normal?  Is it needed for NAT?  Can it be disabled?
Disclaimer
Posting
  ifindex 12(12)
  IP MTU 1492
My guess, might be related to NAT.
You need to run with CEF exclusively. The router is not designed to work without.
Thank you for the information Paolo.
Ian Stephens
Do you think that if I configure a single direct Ethernet interface on the inside instead of using the Vlan this would help with the CPU pegging? Just a thought.
Disclaimer
Posting
I doubt it.
One other possible CPU consumer is the router dealing with fragmentation because of your PPoE, but don't see a way to avoid it because your are PPoE.  With your configuration, since you also have the mss-adjust for TCP, unlikely there's much of this happening.
Any log with "fragment table has reached its maximum" ?
Any change on CPU with "no ip virtual-reassembly" ?
http://www.cisco.com/en/US/docs/ios-xml/ios/security/d1/sec-cr-i3.html#GUID-70035BE4-0286-4E4C-8B59-263F64069CA4
I have applied the following to both the Dialer0 and the Vlan1 interfaces:
no ip virtual-reassembly in
However, CPU is still 99% when traffic is heavy.
How can I check the fragment table?  Sorry, I'm quite new to all of this.
Thank you very much for your help.
sh ip virtual-reassembly
