$100 Reward - MGX 8950 Help
aczwicker
Ive been trying to figure out what is wrong with this MGX8950 for a while now, it keeps repeating the following....(i attached a longer file)
Also, Ive tried 4 different PXM-HD backcards and 3 different PXM 45/C.
I even went as far as dismounting all of the linecards and using 2 different UI-S3 cards.
Any suggestions?
This item was shipped to us via freight on a pallett and all we know is that it came out of service from somewhere that was using it.
I do not know much about these, i have a basic knowledge of the cisco interface.
I Need to be able to test the cards and get a basic configuration. I work for a company that resells this equipment. I will pay anyone $100 that can show me how to configure these either through a semi-detailed email (aczwicker@comcast.net or by calling me @ 503-779-7999
start type 0xc22a0015
Mem size 0x20000000
Clear Edac...        done.
Verify Checksum... Valid
Loading from 0xbfc19398
Starting at addr/reset type a0010000 c22a0015
start addr & end  . . . . . . . . . . . . : 80014fd0 800fa348
start addr & offset . . . . . . . . . . . : bfc04fd0 00019398
Inflating Image to & from . . . . . . . . : a0200000 bfc1e368
Image start & length  . . . . . . . . . . : bfc1e368 000e5378
core_entry addr & inflate time in msec  . : a0200000 00002926
usrInit addr & memory size  . . . . . . . : 802022d4 20000000
BRAM on Mother Board
Probing FP co-processor... Found
Setup SIO device...
                   ÿ
Reinitializing DRAM...completed
rst type & STATUS: c22a0015 34007380
C0_EPC  & CAUSE  : 002151b0 00000c00
C0_CNFG & ErrPC  : 8000c08b bfc00940
RA_reg  & SPR_reg: bfc00914 80000400
reset reason     : 00000000
bootstrap        : 005.002.000.200 20050913-010719
romBoardCacheReset Entry
romBoardCacheReset Exit
Mem size 0x20000000
Clear Edac...        done.
Setup SIO device...
                   ÿ
(REPEATS FOREVER)
paolo bevilacqua
The device you got is (was) meant for large telecoms and require extensive training to be configured and operated.
Not many people know how do that and even less may be available to share occasionally their knowledge for a nominal fee.
Good luck.
