10K router (bandwidth vs priority)
mailaglady2
I am trying to configure QoS in such a way that I allocate the first 30 percent of my bandwith to voice traffic. The router cannot allow bandwidth and priority configured on the same class, how can I realize the goal of allcating the first 30 percent.
Router configs
policy-map QoS
class RT
bandwidth percent 30
% Command accepted but obsolete, unreleased or unsupported; see documentation.
bandwidth and priority may not be combined in the same class.
When I remove the bandwidth command and try to use priority it don't give the option to set up the amount of bandwidth to be allocated on this class.
Joseph W. Doherty
I haven't worked with 10K series, and you didn't described actual platform and IOS, but does 2nd bullet in the following apply?
"Bandwidth and Priority Service
To configure priority queuing, use the priority command in policy-map class configuration mode and configure the bandwidth in the following way:
•In releases prior to Cisco IOS Release 12.3(7)XI, specify a minimum bandwidth rate using the priority command.
•In Cisco IOS Release 12.3(7)XI and later releases, specify a minimum bandwidth rate using the police command. The router no longer supports the percent and bandwidth-kbps options for the priority command. "
From: http://www.cisco.com/en/US/docs/routers/10000/10008/configuration/guides/qos/10qbwdth.html#wp1041808
