12.1 and ACL problems...
hoopteyxx
Greetings all!
I am trying to deny all traffic through my WAN except for web, ssh, ftp, pop3, and smtp... I've got those services running behind my 2611 at a soho sized location...
I've applied the following acl to the interface, and unfortunately it's cutting off my LAN's access to anything outside the router...
permit tcp any any eq www
permit tcp any any eq ftp
permit tcp any any eq pop3
permit tcp any any eq smtp
permit tcp any any eq 22
deny ip any any
What the heck am i doing wrong, here?
you also need to allow DNS, in addition to any routing protocol traffic that you might be running. For the DNS (which is necessary for your web access), add the following to your access list:
permit tcp any any eq domain
If you are running a routing protocol, you will need to allow that traffic as well...
HTH,
GP
The point about DNS is well taken. But the DNS querry requires a UDP permit. The TCP DNS is for zone transfers which is not the issue here.
There is also a question about which interface and which direction the access list is being applied.Depending on direction it might be
or it might be
mpermit tcp any eq www any
Rick
Rick
