12.4T in a c7206VXR NPE-G1
antonio.guirado
Level 3
Level 3
I need some features that only are available in a IOS 12.4T. My router is a c7200VXR with NPE-G1 (see show version).
The issue is that I don't know if there is a IOS 12.4T available for my plataform. I have found it only for NPE-G2.
show version
Cisco IOS Software, 7200 Software (C7200-IS-M), Version 12.4(25f), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 16-Aug-11 10:28 by prod_rel_team
ROM: System Bootstrap, Version 12.2(20030826:190624) [BLD-npeg1_rommon_r11 102], DEVELOPMENT SOFTWARE
FINTGR-LNS-RT02 uptime is 5 hours, 39 minutes
System returned to ROM by reload at 12:53:33 CEST Mon Nov 7 2011
System image file is "disk2:c7200-is-mz.124-25f.bin"
Last reload reason: Reload command
Cisco 7206VXR (NPE-G1) processor (revision A) with 229376K/32768K bytes of memory.
Processor board ID 31521906
SB-1 CPU at 700MHz, Implementation 1025, Rev 0.2, 512KB L2 Cache
6 slot VXR midplane, Version 2.7
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 400 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
4 Gigabit Ethernet interfaces
509K bytes of NVRAM.
62976K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
6 Replies 6
vmiller
Level 7
Level 7
The NPE-G1 is supported in 12.2(4)BW, 12.2(15)B,  12.2(14)S, 12.2(14)SU, 12.2(15)T, 12.1(14)E, 12.3(1), 12.3(2)T,  12.0(28)S, 12.3(1a)B, and later Cisco IOS releases. For the most current  release information, refer to
http://tools.cisco.com/Support/Fusion/FusionHome.do
Its end of sale. Can't even pull up a G1 in the downloads area.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Looks to me like 12.4T should be available.  See attachment.
The question would be, Will it run on the G1? Thats the piece I couldn't prove.
Disclaimer
Posting
It should on any 7200 that's not a G2.
I have an NPE-G1 with 1GB of memory:
cisco 7206VXR (NPE-G1) processor (revision C) with 983040K/65536K bytes of memory.
Processor board ID 16066263
SB-1 CPU at 700MHz, Implementation 1, Rev 0.2, 512KB L2 Cache
6 slot VXR midplane, Version 2.0
It was running a 12.3 version of code:
c7200-is-mz.123-15b.bin
I loaded 12.4T onto the router:
c7200-advipservicesk9-mz.124-15.T3.bin
But the router will not load the software.  I need to check the error messages (router is remote, location now down).
I tried using the Cisco Tool (find software for my hardware platform) and when I selected NPE-G1 as a processor, it said that I had two NPEs, and then gave me the choice of choosing 7200 (all?) or 7200-NPE-G2.  I chose 7200 and it said that this version of code was okay, requiring 512M of RAM.
Any ideas on why it would crash?  The same image is running in a 7200-NPE-400, so I know it's not corrupt.
-rb
antonio.guirado
Level 3
Level 3
finally I could download a 12.4T IOS and install in my device. It works fine.
