128M compact flash card for router 2811
xiaoliangyue
Hi, I use a compact flash reader to copy ios image and cme files from PC to the flash card, and insert it to the router. While booting, it reports
% Crashinfo may not be recovered at flash:crashinfo
% This file system device reports an error
On CLI,
Router#show flash:
%Error show flash: (No such device)
The ios image was actually booted. The file format I used for the card is FAT.
How this happened,and how to resolve it?
Jon
Rick Morris
Level 6
Level 6
format the card
insert into router
format the flash in the router
Copy the IOS from a TFTP server to your flash.
copy tftp flash:
You will need basic network connection from your router, download a free tftp software pack from the internet. Set up your workstation as a TFTP server and make sure the IOS is in the right directory specified by the TFTP software during set-up.
With no IOS on the router it may boot up in rommon so you might need to do this via rommon commands:
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a0080110ed1.shtml
thx for reply. I tried all of these. the key is format doesn't pass thru:
Router#format flash:
Format operation may take a while. Continue? [confirm]
Format operation will destroy all data in "flash:". Continue? [confirm]
%Error formatting flash: (No such device)
I tried Xmodem on ROMMon mode, failed, too.
