1760 QoS Problems
jrichterkessing
I have a 2-person remote office that has Time Warner RoadRunner internet access for WAN connectivity (7Mb down, 768K up), we have a 1760 router (12.4(25d))  installed behind the cable modem and using it to build a VPN tunnel to our datacenter head end VPN router. Installed in the router is a 4-port ethernet switch WIC used to connect the users phones and PCs. I know this is not an ideal configuration for running VoIP traffic, but it's what I have to work with at the moment.
The problem I am having is with the service policy I believe, we mark the voice traffic at the phone "ef", so I am building a service policy based on that marking and allocating 140K of BW. Data connectivity seems to be fine, but when one of the users gets on a phone call everything slows to almost a halt on the data side, during the call the user can hear the conversation just fine but the other end of the call is cut out, garbled, etc. When running a PingPlotter trace to the public address of the router I see very high latency with numerous drops when the user is on the phone. When I take the service policy off of the Fa0/0 interface, the calls are still bad but data connectivity is not affected during a call.
Am I doing the wrong thing by trying to allocate BW for ef traffic? Or should I just trust the markings and have the router put them in the proper queues? Below is my config as it pertains to QoS/interfaces/etc.......any help would be greatly appreciated!
Thanks.
class-map match-all VoIP
match access-group name VoIP
policy-map Apply-QoS
class VoIP
  priority 140
class class-default
  bandwidth remaining percent 100
crypto isakmp policy 2
encr 3des
hash md5
authentication pre-share
group 2
lifetime 36000
crypto isakmp identity hostname
crypto isakmp keepalive 120
crypto isakmp peer address ###.###.###.###
set aggressive-mode password &8UsdD$#aaYtTf6DI43LJ
set aggressive-mode client-endpoint ****.**********.com
crypto ipsec security-association lifetime seconds 36000
crypto ipsec transform-set GMACI-Trans2 esp-3des
crypto ipsec profile vpnprof1
set transform-set GMACI-Trans
crypto map GMACIMAP 100 ipsec-isakmp
description TunnelToWinston
set peer ###.###.###.###
set transform-set GMACI-Trans2
match address VPNACL
qos pre-classify
interface FastEthernet0/0
ip address dhcp
load-interval 30
speed auto
crypto map GMACIMAP
service-policy output Apply-QoS
interface FastEthernet0/1
switchport access vlan 2
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface Vlan1
no ip address
interface Vlan2
ip address 10.52.213.193 255.255.255.224
ip helper-address 10.32.100.6
ip forward-protocol nd
ip route 10.0.0.0 255.0.0.0 10.48.1.1
ip route ###.###.###.### 255.255.255.255 0.0.0.0
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Try:
class VoIP
  priority 140
class class-default
fair-queue
policy-map Apply-QoS-shape
class class-default
  shape average 768000
  service-policy Apply-QoS
ip address dhcp
load-interval 30
speed auto
crypto map GMACIMAP
service-policy output Apply-QoS-shape
