QoS - Help
Alcides Miguel
I configuring QoS policing in a Cisco 2911 in a 128K/256/512 link, but when I apply the configuration in interface I receive the error below:
Configured Percent results in out of range kbps.Allowed range is 8-2000000.
The present CIR value is 6.
Current configuration : 191 bytes
interface GigabitEthernet0/1
description ***V-SAT***
bandwidth 128
ip address 10.150.11.50 255.255.255.252
duplex full
speed 100
max-reserved-bandwidth 100
end
class-map match-all VOICE
  description IP Phones mark Voice to EF
   match ip dscp ef
class-map match-all INTERACTIVE-VIDEO
   description Recommended markings for IP/VC
   match ip dscp af41 af42
class-map match-any CALL-SIGNALING
   description Future Call-Signaling marking
   match ip dscp cs3
   description Current Call-Signaling markin
   match ip dscp af31
class-map match-all ROUTING
    description Routers mark Routing traffic to CS6
match ip dscp cs6
class-map match-all NET-MGMT
    description Recommended marking for Network Management
match ip dscp cs2
class-map match-any MISSION-CRITICAL-DATA
    description Interim marking for Mission-Critical Data
match ip dscp 25
    match access-group name Production-Servers
class-map match-all TRANSACTIONAL-DATA
    description Recommended markings for Transactional Data
match ip dscp af21 af22
class-map match-all BULK-DATA
    description Recommended markings for Bulk Data
match ip dscp af11 af12
class-map match-all SCAVENGER
    description Recommended marking for Scavenger traffic
match ip dscp cs1
policy-map BRANCH-WAN-EDGE
class VOICE
  priority percent 25
class CALL-SIGNALING
  bandwidth percent 5
class ROUTING
  bandwidth percent 3
class NET-MGMT
  bandwidth percent 2
class MISSION-CRITICAL-DATA
  bandwidth percent 23
  random-detect
class TRANSACTIONAL-DATA
  bandwidth percent 12
  random-detect dscp-based
class BULK-DATA
  bandwidth percent 4
class SCAVENGER
  bandwidth percent 1
class class-default
  bandwidth percent 25
  random-detect
policy-map SHAPE-WAN-128
class class-default
  shape average 128000
  service-policy BRANCH-WAN-EDGE
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
So what should be your sugestion to correct this issue in my config?
Don't use a percertage less than 7%.
Besides that, I would imagine your 2911 is running a IOS version that supports HQF CBWFQ.  If so, you may not need the max-reserved-bandwidth 100.  Also if HQF, you could consider a 4 class model, with 1 LLQ and 3 classes using FQ.  Provision bandwidth requirement for LLQ and split remaining bandwidth in something like a 81:9:1 ratio.  The 81% class should have priority traffic that's not real-time, the 9% class is for most of your traffic, and the 1% class is for less than best effort.  (If 1% remaining doesn't take either, adjust to minimum acceptable value and adjust other class bandwidths, except LLQ's.)
7 Replies 7
Joseph W. Doherty
Disclaimer
Posting
CBWFQ polices, I believe, have a bandwidth minimum setting of 8K, which would be 6.25% of 128 K.  So, any class percentage less than 7% might be a too small value.
Hi Joseph,
best regards,
Alcides Miguel
Disclaimer
Posting
Hi Joseph,
I've applied the changed configuration and was successfully can please take a closer look at the script and suggest me modification. just to advice that I'm new to QoS area.
class VOICE
  priority percent 20
  bandwidth percent 8
class ROUTING
  bandwidth percent 7
class NET-MGMT
  bandwidth percent 8
  bandwidth percent 18
  random-detect
  bandwidth percent 10
class BULK-DATA
  bandwidth percent 7
class SCAVENGER
  bandwidth percent 7
class class-default
  bandwidth percent 15
  random-detect
policy-map SHAPE-WAN-256
class class-default
  shape average 256000
interface GigabitEthernet0/2
description ### BRANCH-2-HQ ###
bandwidth 256
ip address 176.26.60.254 255.255.255.254
duplex auto
speed auto
service-policy output SHAPE-WAN-256
end
Disclaimer
Posting
class-map match-any VOICE
   match ip dscp ef
class-map match-any Foreground
   match ip precedence 2 3 4
   match ip precedence 6 7
class-map match-any Background
   match ip precedence 1
class VOICE
  priority percent 30
class Foreground
  bandwidth remaining percent 81
  fair-queue
class Background
  bandwidth remaining percent 1
  fair-queue
class class-default
  bandwidth remaining percent 9
  fair-queue
In above, if percentages cause the error you've seen before, try 21:21:7 or 28:14:7, etc.
Also in above, "Normal" traffic isn't described in class-maps, so it goes into class-default.
I'm also matching using mainly IP Precedence, which encompasses the corresponding DSCP class, e.g. IP Prec 2 matches CS2, AF2x (this makes for a little faster matching on a software based router).
Normally I recommend against using WRED, unless you really know how to use it.  FQ in each class will divide bandwidth between flows within that class, fairly, and should first drop packets from flows filling the class's queues.
Hi Joseph,
many thanks for your help was very helpful.
but as you said traffic like mail and other corporate traffic will goes into class-default?
best regards,
Alcides Miguel
Disclaimer
Posting
Basically, anything with a IP Precedence of zero.
