1760 with WIC-4ESW and 3550
jasonshaffner
I have had 2 3550's connected to my home router, they've been working fantastically together with a trunk on gi0/2, a printer, computer and some NAS drives on various fa ports on both switches. I've been using one VLAN for everything and have had no issues.
Now I'm trying to add a 1760 with a WIC-4ESW card to the network in place of my home router. I've set up fa0/0 as my WAN port, directly connected to my cable modem and I am able to ping out to the internet. I've set up fa1/1 as a trunk, carrying the VLAN I had set up on my switches. I am able to ping all devices on the switches from the router.
Now the issue I'm having is that I cannot access the internet from anything on the other side of the router. I'm a little baffled at this time as I figure if I can access the internet from the router, and I can access the router from the switches and my PC, I should be able to access the internet from my PC. My end goal is to be able to set this up, and attach my home router to one of the switches to use for Wi-Fi, and have my web server, printers and NAS drives in separate VLANs... of course I need to sort this issue out first. Here are my current configs:
1760 Router:
Current configuration : 1818 bytes
version 12.4
hostname rtr1
boot-start-marker
boot-end-marker
aaa new-model
aaa session-id common
resource policy
clock timezone est -5
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
ip dhcp update dns both
no ip domain lookup
ip domain name shaffner.us
ip name-server 8.8.8.8
interface FastEthernet0/0
ip address dhcp
ip access-group 110 in
ip access-group 101 out
ip nat outside
ip nat enable
speed 100
full-duplex
vlan-range dot1q 1 1005
  bridge-group 24
  exit-vlan-config
no cdp enable
interface Serial0/0
no ip address
shutdown
interface FastEthernet1/1
switchport trunk native vlan 24
switchport mode trunk
interface FastEthernet1/2
switchport access vlan 24
interface FastEthernet1/3
shutdown
interface FastEthernet1/4
shutdown
interface Vlan1
no ip address
interface Vlan24
ip address 10.0.1.30 255.255.255.0
ip nat inside
ip nat enable
ip route-cache policy
interface Vlan55
no ip address
ip default-gateway 10.0.1.1
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
no ip http server
access-list 101 permit ip any any
access-list 110 deny   tcp any host 173.194.5.0 eq www
access-list 110 deny   tcp 173.194.55.0 0.0.0.255 eq www any
access-list 110 deny   tcp 206.111.0.0 0.0.255.255 eq www any
access-list 110 permit tcp any any eq www
access-list 110 permit icmp any any
access-list 110 permit ip any any
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password
transport input telnet
end
3550 Switch 1:
Current configuration : 2598 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname swt1
ip subnet-zero
ip name-server 10.0.1.1
interface FastEthernet0/1
switchport trunk allowed vlan 1-1005
no ip address
interface FastEthernet0/2
no ip address
interface FastEthernet0/3
no ip address
interface FastEthernet0/4
no ip address
interface FastEthernet0/5
no ip address
interface FastEthernet0/6
no ip address
interface FastEthernet0/7
no ip address
interface FastEthernet0/8
no ip address
interface FastEthernet0/9
no ip address
interface FastEthernet0/10
no ip address
interface FastEthernet0/11
no ip address
interface FastEthernet0/12
no ip address
interface FastEthernet0/13
no ip address
interface FastEthernet0/14
no ip address
interface FastEthernet0/15
no ip address
interface FastEthernet0/16
no ip address
interface FastEthernet0/17
no ip address
interface FastEthernet0/18
no ip address
interface FastEthernet0/19
no ip address
interface FastEthernet0/20
no ip address
interface FastEthernet0/21
no ip address
interface FastEthernet0/22
no ip address
interface FastEthernet0/23
no ip address
interface FastEthernet0/24
no ip address
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan1
no ip address
interface Vlan24
ip address 10.0.1.20 255.255.255.0
ip default-gateway 10.0.1.30
ip classless
ip http server
line con 0
password
login
line vty 0 4
password
login
line vty 5 15
password
login
end
3550 Switch 2:
Current configuration : 3390 bytes
version 12.2
no service pad
hostname swt2
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
switchport mode dynamic desirable
switchport mode access
switchport nonegotiate
duplex full
description swt1
interface Vlan1
no ip address
interface Vlan5
no ip address
interface Vlan24
ip address 10.0.1.10 255.255.255.0
interface Vlan55
no ip address
ip classless
ip http server
ip http secure-server
control-plane
line con 0
line vty 0 4
password
login
line vty 5 15
password
login
end
Seb Rupik
Hi Jason,
Looks like a NAT issue. You have defined the interfaces, but not the NAT (PAT). The piece of config you need on the 1760 is:
ip nat inside source interface fa0/0 overload
...this should translate all outbound traffic onto a port of the fa0/0 interface using the IP address it was asigned via DHCP.
Once configred run :
sh ip nat trans
...and you should see the translations in action.
cheers,
Seb.
Seb Rupik
Hi Jason,
sh ip nat trans
cheers,
Seb.
jasonshaffner
Thank you, worked perfectly!
