861Router
scsawyer
                   Hello i have a new 861 router no wireless or anything and i am having trouble gettting it to work. i put the IP address on the Fastethernet 4 and the inside ip address on the VLAN1 i can ping out from the router both ways to the gateway and back to the local machine but i can not get out to the internet from the local machines.the DHCP works just cant get to the internet
below is a copy of current config any help would be great.
hostname 861router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-3456406442
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3456406442
revocation-check none
rsakeypair TP-self-signed-3456406442
crypto pki certificate chain TP-self-signed-3456406442
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33343536 34303634 3432301E 170D3036 30313032 31323231
  34315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 34353634
  30363434 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100D7A9 53C08EAE 1558F10B AE84A678 A0C98D33 AB41472B 9D4248DA 0675896C
  E7CF40E4 E634905F 17F0E3F2 A35013BC 93204847 3AF54F16 44321BC8 72DFAEE5
  0DE1D6FD D5BC7190 A973E790 8982ED1C 29E5ADDC 8EC06918 6375A32E D2274953
  21286478 9FE65AF0 A0E6FE38 8953F3B5 7BA52054 F92FF817 662197F8 5744A8C8
  30090203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1483DEC0 6CEEAF08 85AB21E1 E00C85F2 F438E12A EA301D06
  03551D0E 04160414 83DEC06C EEAF0885 AB21E1E0 0C85F2F4 38E12AEA 300D0609
  2A864886 F70D0101 05050003 8181005E 4DEEDF37 6D619DAD 6A91E463 AB1B7EE7
  8340BB76 2FC84662 B9DCE3F1 5F3FADB0 D83AE457 9392C3EC 4FD15173 487D54F8
  F9F4286D C56820FB 0AF9DEB2 AA6FDC56 19F181A2 82CA2D07 2AE15644 2C224F4F
  9FC2E1CF F396724D A5003947 306921F9 A38B7CC4 B72B94AA D9C76774 B4FCC4D7
  CB65C7D6 B833F6F7 BD879AA6 94A8F3
   quit
ip source-route
ip dhcp excluded-address 192.168.4.1 192.168.4.10
ip dhcp excluded-address 192.168.4.200 192.168.4.250
ip dhcp pool PPool
import all
network 192.168.4.0 255.255.255.0
default-router 192.168.4.1
dns-server 10.5.60.2
domain-name domain
lease 0 2
ip cef
no ip domain lookup
license udi pid CISCO861-K9 sn FGL1708240F
username admin privilege 15 secret 4 password
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description outside wan
ip address 10.5.35.1 255.255.0.0
duplex auto
speed auto
interface Vlan1
ip address 192.168.4.1 255.255.255.0
ip nat enable
ip virtual-reassembly out
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.5.10.1
ip route 192.168.4.0 255.255.255.0 10.5.10.1
access-list 4 permit any
access-list 23 permit 192.168.4.0 0.0.0.255
access-list 110 permit ip any any
no cdp run
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
end
hostname 861router
boot-start-marker
boot-end-marker
no aaa new-model
   quit
ip source-route
ip dhcp pool PPool
import all
domain-name domain
lease 0 2
ip cef
no ip domain lookup
no ip address
no ip address
no ip address
no ip address
duplex auto
speed auto
interface Vlan1
ip nat enable
ip http server
no cdp run
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
end
mfurnival
Level 4
Level 4
As mentioned you need to configure NAT properly.
Something like:
interface fa0/4
ip nat outside
interface vlan1
ip nat inside
ip nat inside source list 4 interface fa0/4 overload
And remove this line - you don't need it:
I am curious as to what else you have upstream of this router - you are natting from one private range to another so there will need to be something further upstream that can NAT this traffic to a routable address.
paolo bevilacqua
You need to configure nat properly. You can search documention or the forum on the subject.
mfurnival
Level 4
Level 4
Something like:
interface fa0/4
ip nat outside
interface vlan1
ip nat inside
Hey thanks for the info that worked greate, right now it is just on local network but i will be changing the addresses on it and moving it to another site.
Thanks so much
