1800 to ISP with DHCP
DoubleTapNY
Folks, I need your help.
I am trying to setup a router to the ISP with DHCP and it just isn't working.  The goal is to eventually have a fog server on the inside managing IP's for 24 systems, but I can't even get the Ubuntu machine to ping the outside.  Please take a look at my setup and see what I am missing.  It shouldn't be that hard, but I am not seeing the error and could use some fresh eyes.
EDIT:  The image was made in Cisco Packet tracer to help illustrate what I am trying to accomplish.
Thank you,
8 Replies 8
Jaderson Pessoa
As your image showing to us, both interfaces are "down" state, how dhco is providing address for this interface?
Here you can found more information about " how to do "
https://learningnetwork.cisco.com/thread/134800
Jaderson Pessoa
*** Rate All Helpful Responses ***
I just mapped it real quick on packet tracer as a visual aid.
luis_cordova
Hi @DoubleTapNY
Try this change:
ip nat inside source list 50 interface f0/0 overload
The interface to be overloaded must be that of exit to the ISP.
Thank you for the suggestion.  I made the change, but no success.
Hi @DoubleTapNY
Just to discard, have you disabled the firewall before trying the ping?
Sometimes the firewalls block the ping
After the change the settings look ok.
I suggest you check if there are any rules that prevent connectivity.
Yes, I verified the firewall was disabled.  I've attached a screenshot.  Clockwise from the upper right:
- PC connects with IP, but no internet connectivity
- Firewall is down
- Interface Card settings on PC
- sh run on the router
Thank you all for the suggestions, please keep them coming.  I am spent, and will re-attack in the a.m.
Tap Tap
actually, if this is a Packet Tracer project, post the project (.pkt) file, zip it first otherwise the system won't let you upload it...
Nope not a packet tracer project, just a visual aid.
