Bookmark
Subscribe
3399
IOS XE 16.06.04 and NIM-4G-LTE - Interface not obtaining IP address
Alex Willoughby
Morning All,
Were having an issue with a 4G modem on one of our routers. We never seem to obtain an IP address. We have another modem in a different router configured the same way and that one works without issue (but on a different provider) we have reached out to vodaphone who have confirmed our APN settings are correct. Confirmed there is Data on the SIM and all is working from their point of view, but for some reason we can't see to get it up!
We downgraded the IOS to 16.06.04 from 10.10a, to match the working device, have checked everything we can and still no luck, does anyone have any other suggests or debug commands and output to look for that may be useful in diagnosing this?
Thanks for any help
Config:
Building configuration...
Current configuration : 24078 bytes
! Last configuration change at 15:23:24 UTC Mon Dec 16 2019 by alexw
! NVRAM config last updated at 15:24:32 UTC Mon Dec 16 2019 by alexw
version 16.6
service call-home
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Router1
boot-start-marker
boot system bootflash:isr4300-universalk9.16.06.04.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
logging buffered 10000
logging persistent
enable secret 5 ghjfghjfhgjfhgj
aaa new-model
aaa authentication login default group local
aaa authentication enable default group enable
aaa authorization console
aaa session-id common
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 2:00
no ip bootp server
ip name-server 8.8.8.8
ip domain name device.com
subscriber templating
crypto pki trustpoint TP-self-signed-3549110520
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3549110520
 revocation-check none
 rsakeypair TP-self-signed-3549110520
crypto pki trustpoint SLA-TrustPoint
 enrollment terminal
 revocation-check crl
crypto pki certificate chain TP-self-signed-3549110520
crypto pki certificate pool
 cabundle nvram:ios_core.p7b
no license feature hseck9
license udi pid ISR4321/K9 sn FDO23151G6V
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
spanning-tree vlan 1,5 priority 0
archive
 log config
  logging enable
  logging size 500
  hidekeys
 path flash:$h.cfg
 maximum 5
username root privilege 15 secret 5 bbbbbbb
redundancy
 mode none
controller Cellular 0/2/0
 lte modem link-recovery rssi onset-threshold -110
 lte modem link-recovery monitor-timer 20
 lte modem link-recovery wait-timer 10
 lte modem link-recovery debounce-count 6
interface GigabitEthernet0/0/0
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/1
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/1/0
 description *** SW-01 - g1/0/48 ***
interface GigabitEthernet0/1/1
 description *** SW-02 - g2/0/48 ***
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface Cellular0/2/0
 description *** Vodaphone sim card ***
 ip address negotiated
 ip nat outside
 ip verify unicast reverse-path
 dialer in-band
 dialer idle-timeout 0
 dialer watch-group 1
 pulse-time 1
interface Cellular0/2/1
 no ip address
 negotiation auto
 vrf forwarding Mgmt-intf
 no ip address
 negotiation auto
interface Vlan1
 no ip address
 shutdown
interface Vlan5
 description *** DATA - 10.10.10.2/24 ***
 ip address 10.10.10.2 255.255.255.0
 ip nat inside
 standby version 2
 standby 5 ip 10.10.10.1
 standby 5 timers 1 3
 standby 5 priority 110
 standby 5 preempt delay minimum 10 reload 120
 standby 5 name VLAN5-HSRP
ip nat inside source list ACL_OUTBOUND-NAT interface Cellular0/2/0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0/2/0
ip ssh time-out 5
ip ssh source-interface Loopback0
ip ssh version 2
ip access-list extended ACL_OUTBOUND-NAT
 permit ip 10.10.10.0 0.0.0.255 any
 deny   ip any any
dialer watch-list 1 ip 8.8.8.8 255.255.255.255
dialer watch-list 1 delay route-check initial 60
dialer watch-list 1 delay connect 1
dialer-list 1 protocol ip permit
control-plane
line con 0
 location CONSOLE
 logging synchronous
 transport input none
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 logging synchronous
 transport input ssh
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
cellular info
Router1#sh cellular 0/2/0 all
Hardware Information
Modem Firmware Version = SWI9X15C_05.05.58.00
Modem Firmware built = 2015/03/04 21:30:23
Hardware Version = 1.0
Device Model ID: MC7304
Package Identifier ID: 1102029_9903299_MC7304_05.05.58.00_00_Cisco_005.010_000
International Mobile Subscriber Identity (IMSI) = xxxx
International Mobile Equipment Identity (IMEI) = xxx
Integrated Circuit Card ID (ICCID) = xxx
Mobile Subscriber Integrated Services
Digital Network-Number (MSISDN) =
Modem Status = Modem Online
Current Modem Temperature = 31 deg C
PRI SKU ID = 1102029, PRI version = 05.10, Carrier = Generic
Profile Information
Profile 1 = INACTIVE* **
PDP Type = IPv4
Access Point Name (APN) = pp.vodafone.co.uk
Authentication = PAP
Username: wap
Password: wap
Profile 2 = INACTIVE
  * - Default profile
 ** - LTE attach profile
Data Connection Information
Profile 1, Packet Session Status = INACTIVE
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current System Time = Sun Jan 6 0:8:40 1980
Current Service Status = No service
Current Service = Unknown
Current Roaming Status = Home
Network Selection Mode = Automatic
Network = voda UK
Mobile Country Code (MCC) = 234
Mobile Network Code (MNC) = 15
Packet switch domain(PS) state = Not attached
Registration state(EMM) = Searching/Not Registered
EMM Sub State = Attaching
Tracking Area Code (TAC) = 0
Cell ID = 0 Radio Information ================= Radio power mode = online LTE Rx Channel Number = 6300 LTE Tx Channel Number = 24300 LTE Band = 20 LTE Bandwidth = 10 MHz Current RSSI = -69 dBm Current RSRP = -103 dBm Current RSRQ = -18 dB Current SNR = -4.3 dB Physical Cell Id = 15 Number of nearby cells = 3 Idx PCI (Physical Cell Id) -------------------------------- 1 15 2 245 3 457 Radio Access Technology(RAT) Preference = AUTO Radio Access Technology(RAT) Selected = LTE Modem Security Information ========================== Card Holder Verification (CHV1) = Disabled SIM Status = OK SIM User Operation Required = None Number of CHV1 Retries remaining = 3 GPS Information ========================== GPS Info ------------- GPS Feature: enabled GPS Mode Configured: not configured GPS Status: NMEA Disabled SMS Information =============== Incoming Message Information ---------------------------- SMS stored in modem = 9 SMS archived since booting up = 0 Total SMS deleted since booting up = 0 Storage records allocated = 25 Storage records used = 9 Number of callbacks triggered by SMS = 0 Number of successful archive since booting up = 0 Number of failed archive since booting up = 0 Outgoing Message Information ---------------------------- Total SMS sent successfully = 0 Total SMS send failure = 0 Number of outgoing SMS pending = 0 Number of successful archive since booting up = 0 Number of failed archive since booting up = 0 Last Outgoing SMS Status = SUCCESS Copy-to-SIM Status = 0x0 Send-to-Network Status = 0x0 Report-Outgoing-Message-Number: Reference Number = 0 Result Code = 0x0 Diag Code = 0x0 0x0 0x0 0x0 0x0 SMS Archive URL = Error Information ================= This command is not supported on 4G modems. Modem Crashdump Information =========================== Modem crashdump logging: off Router11# sh int c0/2/0 Cellular0/2/0 is down, line protocol is down Hardware is 4G WWAN NIM - Global Multimode(Europe) LTE/DC-HSPA+/HSPA+/HSPA/UMTS/EDGE/GPRS Description: *** Vodaphone sim card *** Internet address will be negotiated using IPCP MTU 1500 bytes, BW 50000 Kbit/sec, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation HDLC, loopback not set Keepalive not supported DTR is pulsed for 1 seconds on reset Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 22257 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 1006 packets input, 252948 bytes, 0 no buffer Received 0 broadcasts (0 IP multicasts) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 27091 packets output, 5391212 bytes, 0 underruns 987 output errors, 0 collisions, 23 interface resets 0 unknown protocol drops 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions
9 Replies 9
post the full running configuration, not just snippets. What device is this on (which router model) ?
this is an ISR 4321, added config to original post
make the changes/additions marked in bold to your configuration.
version 16.6
service call-home
hostname Router1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging persistent
aaa new-model
no ip bootp server
enrollment terminal
archive
log config
logging enable
logging size 500
hidekeys
path flash:$h.cfg
maximum 5
redundancy
mode none
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
ip nat outside
--> no ip verify unicast reverse-path
dialer in-band
dialer-group 1
pulse-time 1
no ip address
negotiation auto
no ip address
negotiation auto
interface Vlan1
no ip address
shutdown
interface Vlan5
ip nat inside
standby version 2
ip route 8.8.8.8 255.255.255.255 Cellular0/2/0
ip sla 1
icmp-echo 8.8.8.8 source-interface Cellular0/2/0
frequency 5
ip sla schedule 1 life forever start-time now
ip ssh time-out 5
ip ssh version 2
deny ip any any
control-plane
line con 0
location CONSOLE
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0 4
logging synchronous
transport input ssh
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
Thank you for the suggestions, applied them, no such luck. interface still does not have an IP is down, have reloaded modem again too.
Do you know of any useful debug commands for these modems that may give a hint?
Router1#sh ip int brief
GigabitEthernet0/0/0 unassigned YES NVRAM down down
GigabitEthernet0/0/1 unassigned YES NVRAM down down
GigabitEthernet0/1/0 unassigned YES unset up up
GigabitEthernet0/1/1 unassigned YES unset up up
GigabitEthernet0/1/2 unassigned YES unset down down
GigabitEthernet0/1/3 unassigned YES unset down down
Cellular0/2/0 unassigned YES IPCP down down
try:
debug modem
debug dialer
Also, try and remove the watch group from the interface:
ip nat outside
dialer in-band
--> no dialer watch-group 1
dialer-group 1
pulse-time 1
nothing much coming from them, I also added debug cellular0/2/0 messages all to the list and it churned out the below, not that I can interpret anything from it, can you see anything in it?
Dec 19 14:34:47.585: [Cellular0/2/0]:CNM: SNMP network changed
Dec 19 14:34:47.590: ecell_ipc_rx_handler: IPC RX [36]:
Dec 19 14:34:47.590: IPC  (40 bytes):
 04 00 00 24 00 00 00 00 01 01 00 00 00 03 00 45
 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 00 00 00 00 38 2E 30 30
Dec 19 14:34:47.592: ecell_mgmt_process_ipc_event: IPC Message [400] Received
Dec 19 14:34:47.592: [Cellular0/2/0]:MGMT RX (GSM_CONN_RATE_GET_RESP) (32 bytes):
 00 00 00 00 01 01 00 00 00 03 00 45 00 20 00 00
 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Router1#
Dec 19 14:34:56.800: ecell_ipc_rx_handler: IPC RX [20]:
Dec 19 14:34:56.800: IPC  (40 bytes):
 04 00 00 14 00 00 00 00 01 01 00 00 00 01 00 01
 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Dec 19 14:34:56.801: ecell_mgmt_process_ipc_event: IPC Message [400] Received
Dec 19 14:34:56.801: [Cellular0/2/0]:MGMT RX (HEARTBEAT_NOTIFY) (16 bytes):
 00 00 00 00 01 01 00 00 00 01 00 01 00 10 00 00
Dec 19 14:34:56.802: [Cellular0/2/0]:CNM: HeartBeat message received
Dec 19 14:34:56.802: [Cellular0/2/0]:MGMT TX (CONN_RATE_GET Non-block) (16 bytes):
 00 00 00 00 01 01 00 00 00 02 00 45 00 10 00 01
Router1#
Dec 19 14:34:56.803: ecell_set_gps_led: cw_mgmt->gps_info = 7F94191BE3F8
Dec 19 14:34:56.803:  no change in GPS state 1
Dec 19 14:34:56.819: ecell_ipc_rx_handler: IPC RX [36]:
Dec 19 14:34:56.820: IPC  (40 bytes):
Dec 19 14:34:56.821: ecell_mgmt_process_ipc_event: IPC Message [400] Received
Dec 19 14:34:56.821: [Cellular0/2/0]:MGMT RX (GSM_CONN_RATE_GET_RESP) (32 bytes):
Dec 19 14:34:57.457: [Cellular0/2/0]:MGMT TX (UNKNOWN Non-block) (16 bytes):
 00 00 00 00 01 01 00 00 00 02 00 A9 00 10 00 45
Dec 19 14:34:57.458: [Cellular0/2/0]:MGMT TX (SYSTEM_STATS_GET Non-block) (16 bytes):
 00 00 00 00 01 01 00 00 00 02 00 D6 00 10 00 45
Dec 19 14:34:57.459:  send system stats get msg rc 1
Dec 19 14:34:57.464: ecell_ipc_rx_handler: IPC RX [124]:
Dec 19 14:34:57.464: IPC  (40 bytes):
 04 00 00 7C 00 00 00 00 01 01 00 00 00 03 00 A9
 00 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Dec 19 14:34:57.466: ecell_mgmt_process_ipc_event: IPC Message [400] Received
Dec 19 14:34:57.466: [Cellular0/2/0]:MGMT RX (HOST_STATS_RESP) (120 bytes):
 00 00 00 00 01 01 00 00 00 03 00 A9 00 78 00 00
Dec 19 14:34:57.485: ecell_ipc_rx_handler: IPC RX [158]:
Dec 19 14:34:57.485: IPC  (40 bytes):
 04 00 00 9E 00 00 00 00 01 01 00 00 00 01 00 09
 00 9A 00 00 00 00 00 00 00 00 00 02 00 00 00 00
 00 00 00 04 00 00 00 00
Dec 19 14:34:57.486: ecell_mgmt_process_ipc_event: IPC Message [400] Received
Dec 19 14:34:57.486: [Cellular0/2/0]:MGMT RX (SYS_STATUS_NOTIFY) (154 bytes):
 00 00 00 00 01 01 00 00 00 01 00 09 00 9A 00 00
 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 04
 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00
 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Dec 19 14:34:57.492: Cellular0/2/0: callbak_flag 1 service_status 2 channel number 0
Dec 19 14:34:57.492: Cellular0/2/0: change system mode from 8 to 0
Dec 19 14:34:57.492: [Cellular0/2/0]:MGMT TX (MODEM_INFO Non-block) (16 bytes):
 00 00 00 00 01 01 00 00 00 02 00 01 00 10 00 01
Dec 19 14:34:57.493: [Cellular0/2/0]:MGMT TX (CONN_RATE_GET Non-block) (16 bytes):
Dec 19 14:34:57.494: ecell_set_gps_led: cw_mgmt->gps_info = 7F94191BE3F8
Dec 19 14:34:57.494:  no change in GPS state 1
Dec 19 14:34:57.494: Sending LED message 2 to module
Dec 19 14:34:57.578: ecell_ipc_rx_handler: IPC RX [503]:
Dec 19 14:34:57.578: IPC  (40 bytes):
 04 00 01 F7 00 00 00 00 01 01 00 00 00 03 00 01
 01 F3 00 00 53 57 49 39 58 31 35 43 5F 30 35 2E
 30 35 2E 35 38 2E 30 30
Dec 19 14:34:57.580: ecell_ipc_rx_handler: IPC RX [36]:
Dec 19 14:34:57.580: IPC  (40 bytes):
Dec 19 14:34:57.581: ecell_mgmt_process_ipc_event: IPC Message [400] Received
Dec 19 14:34:57.581: [Cellular0/2/0]:MGMT RX (MODEM_INFO_RESP) (499 bytes):
 00 00 00 00 01 01 00 00 00 03 00 01 01 F3 00 00
 53 57 49 39 58 31 35 43 5F 30 35 2E 30 35 2E 35
 38 2E 30 30 00 72 32 37 00 32 30 31 35 2F 30 33
 2F 30 34 20 32 31 3A 33 30 3A 32 33 00 00 31 2E
 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 00 00 00 00 00 00 00 00 32 33 34 31 35 39 35 32
 33 38 39 37 38 38 33 00 00 00 00 00 00 00 00 33
 35 32 37 36 31 30 36 30 35 35 39 37 35 35 00 00
 00 00 00 46 00 00 00 00 00 00 00 02 00 00 00 00
 00 00 00 04 00 00 00 08 00 00 00 00 00 00 00 00
 00 00 00 00 EA 00 00 00 0F 00 00 00 00 00 00 00
 02 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00
 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 38
 39 34 34 31 30 30 30 33 30 30 33 39 30 39 32 30
 30 31 39 00 00 00 00 00 00 00 00 00 00 00 01 01
 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00
 00 00 00 09 30 33 2E 30 33 2E 31 35 00 00 00 00
 00 00 00 00 00 00 00 00 00 31 31 30 32 30 32 39
 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 35
 2E 31 30 00 00 00 00 00 00 00 00 00 00 00 00 00
 00 00 00
Dec 19 14:34:57.598: Cellular0/2/0: callbak_flag 0 service_status 2 channel number 0
Dec 19 14:34:57.598: Cellular0/2/0: change system mode from 0 to 8
Dec 19 14:34:57.598: [Cellular0/2/0]:MGMT TX (CONN_RATE_GET Non-block) (16 bytes):
 00 00 00 00 01 01 00 00 00 02 00 45 00 10 00 05
Dec 19 14:34:57.599: ecell_set_gps_led: cw_mgmt->gps_info = 7F94191BE3F8
Dec 19 14:34:57.599:  no change in GPS state 1
Dec 19 14:34:57.599: Sending LED message 2 to module
Dec 19 14:34:57.599: ecell_mgmt_process_ipc_event: IPC Message [400] Received
Dec 19 14:34:57.599: [Cellular0/2/0]:MGMT RX (GSM_CONN_RATE_GET_RESP) (32 bytes):
Dec 19 14:34:57.600: [Cellular0/2/0]:CNM: SNMP temperature changed
Dec 19 14:34:57.600: [Cellular0/2/0]:CNM: SNMP service changed
Dec 19 14:34:57.600: [Cellular0/2/0]:CNM: SNMP network changed
Dec 19 14:34:57.617: ecell_ipc_rx_handler: IPC RX [36]:
Dec 19 14:34:57.617: IPC  (40 bytes):
Dec 19 14:34:57.618: ecell_mgmt_process_ipc_event: IPC Message [400] Received
Router1#
Dec 19 14:34:57.618: [Cellular0/2/0]:MGMT RX (GSM_CONN_RATE_GET_RESP) (32 bytes):
Router1#
Dec 19 14:35:02.460: [Cellular0/2/0]:MGMT TX (GSM_API_DORMANCY_GET Non-block) (16 bytes):
 00 00 00 00 01 01 00 00 00 02 00 A1 00 10 00 45
Dec 19 14:35:02.480: ecell_ipc_rx_handler: IPC RX [28]:
Dec 19 14:35:02.481: IPC  (40 bytes):
 04 00 00 1C 00 00 00 00 01 01 00 00 00 03 00 A1
 00 18 00 00 00 00 00 FF 00 00 00 FF 00 00 00 00
Dec 19 14:35:02.482: ecell_mgmt_process_ipc_event: IPC Message [400] Received
Dec 19 14:35:02.482: [Cellular0/2/0]:MGMT RX (GSM_API_DORMANCY_GET_RESP) (24 bytes):
 00 00 00 00 01 01 00 00 00 03 00 A1 00 18 00 00
Router1#
Dec 19 14:35:06.804: ecell_ipc_rx_handler: IPC RX [20]:
Dec 19 14:35:06.805: IPC  (40 bytes):
 00 10 00 00 00 00 00 FF 00 00 00 FF 00 00 00 00
Dec 19 14:35:06.806: ecell_mgmt_process_ipc_event: IPC Message [400] Received
Dec 19 14:35:06.806: [Cellular0/2/0]:MGMT RX (HEARTBEAT_NOTIFY) (16 bytes):
Dec 19 14:35:06.807: [Cellular0/2/0]:CNM: HeartBeat message received
Dec 19 14:35:06.807: [Cellular0/2/0]:MGMT TX (CONN_RATE_GET Non-block) (16 bytes):
Router1#
Dec 19 14:35:06.808: ecell_set_gps_led: cw_mgmt->gps_info = 7F94191BE3F8
Dec 19 14:35:06.809:  no change in GPS state 1
Dec 19 14:35:06.814: ecell_ipc_rx_handler: IPC RX [36]:
Dec 19 14:35:06.814: IPC  (40 bytes):
Dec 19 14:35:06.815: ecell_mgmt_process_ipc_event: IPC Message [400] Received
Dec 19 14:35:06.816: [Cellular0/2/0]:MGMT RX (GSM_CONN_RATE_GET_RESP) (32 bytes):
Dec 19 14:35:07.461: [Cellular0/2/0]:MGMT TX (GSM_API_SIGNAL_STRENGTH_GET Non-block) (16 bytes):
 00 00 00 00 01 01 00 00 00 02 00 A2 00 10 00 45
Dec 19 14:35:07.461: [Cellular0/2/0]:MGMT TX (SYSTEM_STATS_GET Non-block) (16 bytes):
Dec 19 14:35:07.463:  send system stats get msg rc 1
Dec 19 14:35:07.478: ecell_ipc_rx_handler: IPC RX [41]:
Dec 19 14:35:07.478: IPC  (40 bytes):
 04 00 00 29 00 00 00 00 01 01 00 00 00 03 00 A2
 00 25 00 00 00 46 F2 00 00 00 08 FF FF FF 9B FF
 FF FF F2 00 0A 00 FF 00
Dec 19 14:35:07.480: ecell_mgmt_process_ipc_event: IPC Message [400] Received
Dec 19 14:35:07.480: [Cellular0/2/0]:MGMT RX (GSM_API_SIGNAL_STRENGTH_GET_RESP) (37 bytes):
 00 00 00 00 01 01 00 00 00 03 00 A2 00 25 00 00
 00 46 F2 00 00 00 08 FF FF FF 9B FF FF FF F2 00
 0A 00 FF 00 FF
Dec 19 14:35:07.482: [Cellular0/2/0]:CNM: SNMP GSM RSSI changed
Dec 19 14:35:07.488: ecell_ipc_rx_handler: IPC RX [158]:
Dec 19 14:35:07.488: IPC  (40 bytes):
Dec 19 14:35:07.490: ecell_mgmt_process_ipc_event: IPC Message [400] Received
Dec 19 14:35:07.490: [Cellular0/2/0]:MGMT RX (SYS_STATUS_NOTIFY) (154 bytes):
Dec 19 14:35:07.495: Cellular0/2/0: callbak_flag 1 service_status 2 channel number 0
Dec 19 14:35:07.495: Cellular0/2/0: change system mode from 8 to 0
Dec 19 14:35:07.495: [Cellular0/2/0]:MGMT TX (MODEM_INFO Non-block) (16 bytes):
Dec 19 14:35:07.496: [Cellular0/2/0]:MGMT TX (CONN_RATE_GET Non-block) (16 bytes):
Dec 19 14:35:07.497: ecell_set_gps_led: cw_mgmt->gps_info = 7F94191BE3F8
Dec 19 14:35:07.497:  no change in GPS state 1
Dec 19 14:35:07.497: Sending LED message 2 to module
Dec 19 14:35:07.498: Sending LED message 2 to module
Dec 19 14:35:07.580: ecell_ipc_rx_handler: IPC RX [503]:
Dec 19 14:35:07.580: IPC  (40 bytes):
Dec 19 14:35:07.581: ecell_ipc_rx_handler: IPC RX [36]:
Dec 19 14:35:07.581: IPC  (40 bytes):
Dec 19 14:35:07.583: ecell_mgmt_process_ipc_event: IPC Message [400] Received
Dec 19 14:35:07.583: [Cellular0/2/0]:MGMT RX (MODEM_INFO_RESP) (499 bytes):
 00 00 00
Dec 19 14:35:07.596: Cellular0/2/0: callbak_flag 0 service_status 2 channel number 0
Dec 19 14:35:07.596: Cellular0/2/0: change system mode from 0 to 8
Dec 19 14:35:07.596: [Cellular0/2/0]:MGMT TX (CONN_RATE_GET Non-block) (16 bytes):
Dec 19 14:35:07.598: ecell_set_gps_led: cw_mgmt->gps_info = 7F94191BE3F8
Dec 19 14:35:07.598:  no change in GPS state 1
Dec 19 14:35:07.598: Sending LED message 2 to module
Dec 19 14:35:07.599: ecell_mgmt_process_ipc_event: IPC Message [400] Received
Dec 19 14:35:07.599: [Cellular0/2/0]:MGMT RX (GSM_CONN_RATE_GET_RESP) (32 bytes):
Dec 19 14:35:07.600: [Cellular0/2/0]:CNM: SNMP temperature changed
Dec 19 14:35:07.600: [Cellular0/2/0]:CNM: SNMP service changed
Dec 19 14:35:07.600: [Cellular0/2/0]:CNM: SNMP network changed
Dec 19 14:35:07.608: ecell_ipc_rx_handler: IPC RX [36]:
Dec 19 14:35:07.608: IPC  (40 bytes):
Dec 19 14:35:07.611: ecell_mgmt_process_ipc_event: IPC Message [400] Received
Router1#
Dec 19 14:35:07.611: [Cellular0/2/0]:MGMT RX (GSM_CONN_RATE_GET_RESP) (32 bytes):
Router1#
Dec 19 14:35:12.463: [Cellular0/2/0]:MGMT TX (GSM_API_MODEM_CURRENT_STATUS_GET Non-block) (16 bytes):
 00 00 00 00 01 01 00 00 00 02 00 A3 00 10 00 45
Dec 19 14:35:12.493: ecell_ipc_rx_handler: IPC RX [409]:
Dec 19 14:35:12.493: IPC  (40 bytes):
 04 00 01 99 00 00 00 00 01 01 00 00 00 03 00 A3
 01 95 00 00 20 00 01 00 04 00 00 14 03 18 9C 5E
 EC 00 00 00 00 2F 64 65
Dec 19 14:35:12.494: ecell_mgmt_process_ipc_event: IPC Message [400] Received
Dec 19 14:35:12.494: [Cellular0/2/0]:MGMT RX (GSM_API_MODEM_CURRENT_STATUS_GET_RESP) (405 bytes):
 00 00 00 00 01 01 00 00 00 03 00 A3 01 95 00 00
 20 00 01 00 04 00 00 14 03 18 9C 5E EC 00 00 00
 00 2F 64 65 76 2F 74 74 79 55 53 42 32 00 00 00
 00 00 00 00 00 00 00 00 00 2F 64 65 76 2F 74 74
 79 55 53 42 31 00 00 00 00 00 00 00 00 00 00 00
 00 2F 64 65 76 2F 74 74 79 55 53 42 30 00 00 00
 00 00 00 00 00 00 00 00 00 00 01 08 00 00 00 00
 00 00 00 00 00 00 00 00 00 32 30 31 35 2D 30 38
 2D 32 37 2F 53 57 49 5F 32 2E 32 35 3A 47 6F 62
 69 53 65 72 69 61 6C 00 00 32 30 31 35 2D 31 32
 2D 30 38 2F 53 57 49 5F 32 2E 33 36 00 00 00 00
 00 00 00 00 00 00 00 00 58 00 00 00 00 00 00 00
 00 00 00 00 58 00 00 00 00 00 00 00 00 00 00 00
 00 00 00 01 E9
Modem Callback Stats
PacketServiceCallback_count 0
DataBearerCallback_count 0
DormancyStatusCallback_count 0
PowerCallback_count 0
ByteTotalsCallback_count 0
iByteTotalsCallback_count 0
PacketsCountCallback_count 0
iPacketsCountCallback_count 0
ActivationStatusCallback_count 0
MobileIPStatusCallback_count 0
RoamingIndicatorCallback_count 0
DataCapabilitiesCallback_count 88
SignalStrengthCallback_count 0
iSignalStrengthCallback_count 0
RFInfoCallback_count 0
LURejectCallback_count 0
NewSMSCallback_count 0
SLQSSMSEventCallback_count 0
NMEACallback_count 0
PDSStateCallback_count 0
CATEventCallback_count 0
iCATEventCallback_count 0
DeviceStateChangeCbk_count 0
FwDldCompletionCbk_count 0
SLQSOMADMAlertCallback_count 0
OMADMStateCallback_count 0
SLQSServingSystemCallback_count 88
SLQSBandPreferenceCbk_count 0
USSDReleaseCallback_count 0
USSDNotificationCallback_count 0
Router1#SLQSSignalStrengthsCallback_count 0
iSLQSSignalStrengthsCallback_count 0
SLQSSDKTerminatedCallback_count 0
SLQSTransLayerInfoCallback_count 0
SLQSTransNWRegInfoCallback_count 0
SLQSSysSelectionPrefCallBack_count 0
NotifySessionStateDisconnect_count 0
WdsEventCallback_count 0
HeartbeatModemStatisticsCallback 489
Router1#
Dec 19 14:35:16.804: ecell_ipc_rx_handler: IPC RX [20]:
Dec 19 14:35:16.804: IPC  (40 bytes):
 00 10 00 00 20 00 01 00 04 00 00 14 03 18 9C 5E
Dec 19 14:35:16.805: ecell_mgmt_process_ipc_event: IPC Message [400] Received
Dec 19 14:35:16.805: [Cellular0/2/0]:MGMT RX (HEARTBEAT_NOTIFY) (16 bytes):
Dec 19 14:35:16.806: [Cellular0/2/0]:CNM: HeartBeat message received
Dec 19 14:35:16.806: [Cellular0/2/0]:MGMT TX (CONN_RATE_GET Non-block) (16 bytes):
Router1#
Dec 19 14:35:16.807: ecell_set_gps_led: cw_mgmt->gps_info = 7F94191BE3F8
Dec 19 14:35:16.807:  no change in GPS state 1
Dec 19 14:35:16.823: ecell_ipc_rx_handler: IPC RX [36]:
Dec 19 14:35:16.823: IPC  (40 bytes):
Dec 19 14:35:16.825: ecell_mgmt_process_ipc_event: IPC Message [400] Received
Dec 19 14:35:16.825: [Cellular0/2/0]:MGMT RX (GSM_CONN_RATE_GET_RESP) (32 bytes):
Dec 19 14:35:17.463: [Cellular0/2/0]:MGMT TX (API_NETWORK_SYSTEM_INFO_GET Non-block) (16 bytes):
 00 00 00 00 01 01 00 00 00 02 00 A4 00 10 00 45
Dec 19 14:35:17.465: [Cellular0/2/0]:MGMT TX (UNKNOWN Non-block) (16 bytes):
 00 00 00 00 01 01 00 00 00 02 00 CA 00 10 00 45
what is the status of the EN/RSSI/SERVICE LEDs on the router, are they all green ?
Theres no one onsite to take a photo or verify for us, the site is closed at the moment, unfortunately
I think there needs to be some interesting traffic to initialize the cellular interface. Try and configure a loopback, and the source the IP SLA from that interface:
interface Loopback 1
ip address 1.1.1.1 255.255.255.255
ip sla 1
icmp-echo 8.8.8.8 source-interface Loopback1
frequency 5
