1811 Router + PPPOE Help
jrhaile26
I'm hoping someone can look over my config and tell me if there is anything wrong with it or that would cause my ISP's Network to suddenly "crash" as they put it.  What is happening is, it will connect just fine but my ISP keeps shutting off my port because they're saying other people on their network (customers) are suddenly looking to our router for PPPOE Authentication thus causing them down time.  I have told them over and over again there is nothing in my config that is causing this and it is a problem on their side but they just shut off my port until I make "proper changes" so this doesn't happen anymore.
I have NEVER seen or heard of such a problem in me entire 12 years in IT.  Anyways, thanks for any input anyone can give me.
gaspaso#show run
Building configuration...
Current configuration : 2986 bytes
version 12.4
service password-encryption
hostname gaspaso
boot-start-marker
boot-end-marker
enable password 7 052F5E5D1758540101083D
no aaa new-model
dot11 syslog
ip cef
no ip domain lookup
vpdn enable
vpdn-group 1
request-dialin
  protocol pppoe
chat-script MYCHAT ABORT ERROR "" "AT X0\n"
username gaspaso password 7 1536535E323E312C303E1F
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 5
crypto isakmp key <REMOVED> address 65.121.182.2
crypto isakmp keepalive 600 5 periodic
crypto ipsec transform-set VPNSET esp-aes 256 esp-sha-hmac
crypto map VPNMAP 1 ipsec-isakmp
set peer <REMOVED>
set transform-set VPNSET
match address 115
archive
log config
  hidekeys
bba-group pppoe global
interface FastEthernet0
description Fibre Network PPPOE
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly
ip route-cache flow
no ip mroute-cache
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
crypto map VPNMAP
interface FastEthernet1
ip address 172.20.44.155 255.255.255.248 secondary
ip address 172.30.14.155 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no ip mroute-cache
duplex auto
speed auto
no cdp enable
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
no ip address
interface Async1
ip address negotiated
encapsulation ppp
async mode interactive
interface Dialer1
description fibre network
mtu 1491
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
ip route-cache flow
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username <REMOVED> password 7 0009120507
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 65.215.140.0 255.255.252.0 Async1
ip http server
no ip http secure-server
ip nat inside source list 10 interface Dialer1 overload
access-list 10 permit 172.16.253.0 0.0.0.255
access-list 10 permit 172.30.14.0 0.0.0.255
access-list 115 permit ip 172.30.14.152 0.0.0.7 10.240.0.0 0.0.255.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
line 1
script connection MYCHAT
login local
modem InOut
transport input all
autoselect during-login
autoselect ppp
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
password 7 072B791E781D030D0F1F21
login
webvpn context Default_context
ssl authenticate verify all
no inservice
end
gaspaso#
paolo bevilacqua
There are few minor adjustments that you should do in your config, eg MTU should be 1492 not 1491, vpd-group is not required, but beside  that there is nothing that can cause remote equipment to crash.
It seems to me that they are using poor or buggy equipment (could also be Cisco, of course), and do not want to take responsibility in something that really is a problem by their side, as you correctly pointed out.
My recommendation would be to still spend a reasonable amount of time on this, maybe you can take a "debug PPP negotiation" trace, then if they continue to refuse to update their system, switch to a different ISP.
paolo bevilacqua
jrhaile26
Thank you Paolo for your resopnse.  I corrected my typo and removed the group.  As it turns out, the ISP has given up and just assigned me a straight static.  There was clearly something wrong on their side.  Again thank you for your response.
- James
You're welcome, thank you for the nice rating and good luck!
