1812 PPPoE problem
boborg.13
hello!
i'm having a problem establishing a pppoe session with a 1812 router. i've tried everything i could find online, even contacted the isp (all they said was that the modem should be in bridge mode, which it is)...
debug information puts out only
Sep 30 19:51:32:  padi timer expired
Sep 30 19:51:32:  Sending PADI: Interface = FastEthernet1
Sep 30 19:51:32: pppoe_send_padi:
         FF FF FF FF FF FF 00 16 C8 18 31 39 88 63 11 09
         00 00 00 0C 01 01 00 00 01 03 00 04 85 14 0B 60 ...
show ver and show run from the router
Cisco IOS Software, C181X Software (C181X-ADVENTERPRISEK9-M), Version 12.4(15)T3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 24-Jan-08 13:05 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YH5, RELEASE SOFTWARE (fc1)
kronik uptime is 18 minutes
System restarted at 18:53:28 CET-SUMMER Fri Sep 30 2011
System image file is "flash:c181x-adventerprisek9-mz.124-15.T3.bin"
kronik#show run
Building configuration...
Current configuration : 5070 bytes
! Last configuration change at 19:09:57 CET-SUM Fri Sep 30 2011
! NVRAM config last updated at 19:11:18 CET-SUM Fri Sep 30 2011
version 12.4
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname kronik
boot-start-marker
warm-reboot
boot-end-marker
security authentication failure rate 3 log
logging userinfo
logging buffered 30000
logging monitor warnings
no aaa new-model
clock timezone CET 1
clock summer-time CET-SUMMER recurring last Sun Mar 2:00 last Sun Oct 3:00
no ip gratuitous-arps
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.6.66.1 10.6.66.20
ip dhcp pool ###LAN###
   network 10.6.66.0 255.255.255.0
   default-router 10.6.66.1
   dns-server 195.29.150.3 213.147.96.3 4.2.2.2
   lease infinite
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
login block-for 120 attempts 3 within 30
login on-failure log
spanning-tree vlan 1 priority 8192
spanning-tree vlan 666 priority 8192
archive
log config
  hidekeys
bba-group pppoe global
interface FastEthernet0
no ip address
duplex auto
speed auto
no cdp enable
interface FastEthernet1
description ### WAN ###
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 10
no cdp enable
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet2
switchport access vlan 666
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
description ### LINK NA sw04 ###
switchport mode trunk
interface FastEthernet9
description ### LINK NA sw01 ###
interface Vlan1
no ip address
shutdown
interface Vlan666
description LAN
ip address 10.6.66.1 255.255.255.0
ip helper-address 10.6.66.1
ip nat inside
ip virtual-reassembly
interface Dialer10
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1400
dialer pool 10
dialer-group 10
no cdp enable
ppp authentication pap chap
ppp chap hostname xxxxxx
ppp chap password xxxxxx
ppp pap sent-username xxxxxx password xxxxxx
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer10
no ip http server
ip http secure-server
ip nat inside source list NAT_ADRESE interface Dialer10 overload
ip access-list extended NAT_ADRESE
permit ip any any log
dialer-list 10 protocol ip permit
control-plane
alias exec s show ip int brief
alias exec r show ip route
line con 0
privilege level 15
logging synchronous
line aux 0
line vty 0 4
privilege level 5
logging synchronous
login local
terminal-type monitor
transport input ssh
line vty 5 15
privilege level 5
logging synchronous
login local
transport input ssh
ntp master
end
i am going crayz bit by bit....
6 Replies 6
Peter Paluch
Hello bobo,
Keep cool I hope we will get it going.
Can you please start by explaining in more detail how is the router connected to the PPPoE service? Is there an ADSL modem connected to your Fa1 interface? What kind of modem is it?
Best regards,
Peter
yes, it is an ADSL modem (siemens gigaset sx 763), connected to fa1 on the 1812
Hello bobo,
The Gigaset SX 763, according to the manuals I have been able to find, is not an ADSL modem but rather a full ADSL router. Its internal Ethernet ports are routed and do not run PPPoE. If you want to access an ADSL service, you have to configure it on the SX. You do not even need the 1812 as the SX is already performing routing and NAT functions. If you still want to use the 1812, you will need to configure it for plaing IP routing without PPPoE.
I hope I have understood you correctly here - you want to connect over the 1812 and SX to an ADSL service. Is this correct?
Best regards,
Peter
yes, you are correct, i want the 1812 to establish pppoe, perform nat and firewall functions, the sx should just be the bridge to the isp. i turned off all of those fuctions on the sx.
i can not find a combination that works, the router is not receiving pado from the isp...
now i just remembered, the sx has a pbr option, one can either turn it off, or set the fe ports for internet/voice/mgmnt. i haven't tried turning the pbr off. if that does not work i will contact the isp again....
Hello bobo,
I am afraid that you are trying something that is not supported by your SX. You see, the SX is already a (more or less) fully-fledged ADSL router. The PPPoE client is built into it and the entire SX is meant to provide ADSL/PPPoE connectivity without needing any other external device. What you are probably trying is to "degrade" the SX to a mere ADSL modem with Ethernet port on one end and ADSL port on the other. I am not sure if that is possible with the SX model you have. Please do have a very good look into the documentation before even wasting your time to do something that may not be possible with the SX at all.
Best regards,
Peter
well, the mistery is finnaly solved!
there was an issue with the modem, not all of the ports were designated as "internet ports", 2 were meant to be used for iptv (which i don't use), even though one could not see this in the settings of the modem, they were all configured for internet. that was the first problem
after that i could not get the my router to authenicate to the isp, and the debug ppp authenentication gave me this
Oct  4 20:48:40: %DIALER-6-BIND: Interface Vi2 bound to profile Di10
Oct  4 20:48:40: Vi2 PPP: Using dialer call direction
Oct  4 20:48:40: Vi2 PPP: Treating connection as a callout
Oct  4 20:48:40: Vi2 PPP: Session handle[3000000B] Session id[0]
Oct  4 20:48:40: Vi2 PPP: Authorization required
so i google a little bit and found that that i should aply the ppp authentication pap callin command! so i did. and it works now!
it seems a bit unlogical to me because the isp does not have to authenticate to my router, but still, i'm a lot happier now!
thanks everyone for the help!
