877 - No Password Recovery - No IOS
AdamPage1
I have a couple of 877s which have "no service password recovery" set and something has happened to the flash or the IOS has been lost for one reason or another.
When trying to boot the routers, they all display similar to this, which then repeats:
System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
Copyright (c) 2006 by cisco Systems, Inc.
C870 series (Board ID: 1-148) platform with 131072 Kbytes of main memory
PASSWORD RECOVERY FUNCTIONALITY IS DISABLED
Booting flash:/c870-advipservicesk9-mz.124-24.T5.bin
ELF Loader: read error
Elf loader error
Or words to the effect of there being no IOS at all, unable to boot, but the result is the same, it just loops and there's nothing I can do to break the sequence!
I've tried taking the flash from a working 877 and replacing the card but this doesn't work and unfortunately, putting the once working strataflash card back in the working 877, it gets the same problem!
11 Replies 11
Leo Laohoo
Look at the back of the router.  There's a small reset button.
Hold the "Reset" button down, power up the router and wait for about 5 seconds and release.
hi leo,
this is cool! +5
Router(config)#no service password-recovery
WARNING:
Executing this command will disable password recovery mechanism.
Do not execute this command without another plan for
password recovery.
Are you sure you want to continue? [yes/no]: yes
Router(config)#config-register 0x2142
Password recovery is disabled, cannot enable diag or ignore configuration.
Booting flash:/c870-advsecurityk9-mz.124-15.T1.bin
Self decompressing the image : ######################################################### [OK]
Username: cisco
Password:
yourname#
Thanks John.
I've tried this before on several of the routers, but it makes no difference, the router continues to try to boot but can't because of the problem with the IOS and is unable to enter ROMMON because the no password recovery is set.
Just to confirm, when moving the strataflash from another 877 to the bricked one, this error occurs:
flashfs[0]: dir struct error[1].
flash: file system initialization failed
Could not open boot directory: flash:/
Unable to open boot fil
Hi Adam,
It looks like a bad or corrupted flash.
I would suggest to contact TAC and have it RMA'd.
Hi John,
If I remove the flash from the bad router and place it in a good router WITHOUT "no service password recovery" set, then the good router enters ROMMON and I'm able to send a new IOS to the flash and the good router boots find with the bad routers flash. When I then put that flash back in one of the bad routers, it displays the same symptoms. I do not believe there to be any actual problems with the routers or flash, but I believe the IOS was mistakingly deleted and the router rebooted which caused the loop. So it is a conflict between no IOS present in the flash and the "no service password recovery" which causes this seemingly unrepairable state. It's almost as if the no password recovery option encrypts the flash so it can only be read by that router and it can only read a flash from that router at the time the no password recovery was set!
Also, just to note, these routers do not have any current support contract on them, so returning to Cisco is not an option.
This is the message I get on the bad router when I put the "repaired" flash back in
flashfs[0]: inconsistent sector list, fileid 2, parent_fileid 0
flashfs[0]: relinked orphaned file into the fs as "/lost+found/00003".
No bootable image file: flash:/
Unable to open boot file
Routers with password recovery disabled CAN NOT be recovered by any publiclly documented method.
If someone tells you otherwise, challenge to prove you how.
Hey Paolo,
Haven't seen you posting.  Hope everything is fine.
Breaking into a router with "no service password-recovery" enabled is do-able.  I've done this several times as a demo to my colleagues who share your same opinion.  Click here.
leolaohoo wrote:
Hey Paolo,
All is fine and so I hope about you
Sorry to tell that you are wrong, but the example you posted is about a very old router that can have buggy rommon, and if you mread it accurately, it doen;t make any sense. It does not even expalin what the guy did. Beside, I tend not to take seriously posts that begin referencing alcohol ingestion.
Let us know when you can "break into" an ISR router, for example.
