06-20-2013 02:06 AM - edited 03-04-2019 08:15 PM
Have an 1841 ADSLM router (our Gateway on IP: 10.0.0.254) configured for dual WAN:
It was working fine until the router was restarted (which had been done previously without problem).
Now, if I leave the modem connected to FE0/1 we seem to lose internet connectivity. I can ping IP addresses, but getting any amount of data through is difficult.
As soon as I disconnect the modem from FE0/1 (or the ADSL line to the modem) the internet works perfectly.
If I reconnect the modem, when the interface connects to the ISP, we start having problems with our internet again.
Here's a copy of the config:
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname cisco1841
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret 5 $1$GvA.$rwXf74Ujhbpx59dk/iKrG.
no aaa new-model
clock timezone PCTime 10
clock summer-time PCTime date Mar 30 2003 3:00 Oct 26 2003 2:00
dot11 syslog
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
ip domain name cape.local
no ipv6 cef
license udi pid CISCO1841 sn XYZ144411XY
archive
log config
logging enable
notify syslog contenttype plaintext
hidekeys
username cisco privilege 15 secret 5 $1$3/bM$wqa1vZAo.eFofsbmTQy2f.
redundancy
ip tcp synwait-time 10
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
encr 3des
group 2
crypto isakmp key $!$38p3z10! address 203.xyz.xyz.19
crypto ipsec transform-set STRONG esp-des esp-md5-hmac
mode transport
crypto ipsec transform-set CAPE_TSET esp-3des esp-sha-hmac
crypto map CAPE_CRYMAP 10 ipsec-isakmp
set peer 203.xyz.xyz.19
set transform-set CAPE_TSET
match address VPN_TRAFFIC
crypto map CISCO 8 ipsec-isakmp
set transform-set STRONG
match address 124
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to203.xyz.xyz.19
match address 105
crypto map SDM_CMAP_2 1 ipsec-isakmp
match address 106
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$$ES_LAN$$FW_INSIDE$
ip address 10.0.0.254 255.255.255.0
ip flow ingress
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
no ip address
ip nat outside
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 2
interface ATM0/0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
interface ATM0/0/0.1 point-to-point
description $ES_WAN$
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname cape0@myisp.com
ppp chap password 7 075B711B1F5D40
ppp ipcp route default
no cdp enable
interface Dialer1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no cdp enable
interface Dialer2
description LINK TO DSL MODEM
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 2
dialer idle-timeout 0
dialer-group 2
ppp authentication chap pap callin
ppp chap hostname cape2@myisp.com
ppp chap password 7 1241574441525C
ppp pap sent-username cape2@myisp.com password 7 154A595F57737B
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool EXTERNAL 10.245.39.0 10.245.39.254 netmask 255.255.255.0
ip nat source list 50 interface Dialer0 overload
ip nat source list 60 interface Dialer2 overload
ip nat source list 112 pool EXTERNAL overload
ip nat inside source static tcp 10.0.0.2 25 interface Dialer0 25
ip nat inside source static tcp 10.0.0.2 443 interface Dialer0 443
ip nat inside source static tcp 10.0.0.2 80 interface Dialer0 80
ip nat inside source static tcp 10.0.0.2 1723 interface Dialer2 1723
ip nat inside source static tcp 10.0.0.2 110 interface Dialer0 110
ip nat inside source static tcp 10.0.0.2 143 interface Dialer0 143
ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload
ip nat inside source route-map VPN_RMAP pool EXTERNAL overload
ip nat inside source static tcp 10.0.0.50 449 10.245.39.250 449 extendable
ip nat inside source static udp 10.0.0.50 449 10.245.39.250 449 extendable
ip nat inside source static tcp 10.0.0.50 515 10.245.39.250 515 extendable
ip nat inside source static udp 10.0.0.50 515 10.245.39.250 515 extendable
ip nat inside source static tcp 10.0.0.50 8470 10.245.39.250 8470 extendable
ip nat inside source static udp 10.0.0.50 8470 10.245.39.250 8470 extendable
ip nat inside source static tcp 10.0.0.50 8471 10.245.39.250 8471 extendable
ip nat inside source static udp 10.0.0.50 8471 10.245.39.250 8471 extendable
ip nat inside source static tcp 10.0.0.50 8472 10.245.39.250 8472 extendable
ip nat inside source static udp 10.0.0.50 8472 10.245.39.250 8472 extendable
ip nat inside source static tcp 10.0.0.50 8473 10.245.39.250 8473 extendable
ip nat inside source static udp 10.0.0.50 8473 10.245.39.250 8473 extendable
ip nat inside source static tcp 10.0.0.50 8474 10.245.39.250 8474 extendable
ip nat inside source static udp 10.0.0.50 8474 10.245.39.250 8474 extendable
ip nat inside source static tcp 10.0.0.50 8475 10.245.39.250 8475 extendable
ip nat inside source static udp 10.0.0.50 8475 10.245.39.250 8475 extendable
ip nat inside source static tcp 10.0.0.50 8476 10.245.39.250 8476 extendable
ip nat inside source static udp 10.0.0.50 8476 10.245.39.250 8476 extendable
ip nat inside source static tcp 10.0.0.50 9100 10.245.39.250 9100 extendable
ip nat inside source static udp 10.0.0.50 9100 10.245.39.250 9100 extendable
ip nat inside source static 10.0.0.50 10.245.39.250
ip nat inside source static tcp 10.0.0.51 449 10.245.39.251 449 extendable
ip nat inside source static udp 10.0.0.51 449 10.245.39.251 449 extendable
ip nat inside source static tcp 10.0.0.51 515 10.245.39.251 515 extendable
ip nat inside source static udp 10.0.0.51 515 10.245.39.251 515 extendable
ip nat inside source static tcp 10.0.0.51 8470 10.245.39.251 8470 extendable
ip nat inside source static udp 10.0.0.51 8470 10.245.39.251 8470 extendable
ip nat inside source static tcp 10.0.0.51 8471 10.245.39.251 8471 extendable
ip nat inside source static udp 10.0.0.51 8471 10.245.39.251 8471 extendable
ip nat inside source static tcp 10.0.0.51 8472 10.245.39.251 8472 extendable
ip nat inside source static udp 10.0.0.51 8472 10.245.39.251 8472 extendable
ip nat inside source static tcp 10.0.0.51 8473 10.245.39.251 8473 extendable
ip nat inside source static udp 10.0.0.51 8473 10.245.39.251 8473 extendable
ip nat inside source static tcp 10.0.0.51 8474 10.245.39.251 8474 extendable
ip nat inside source static udp 10.0.0.51 8474 10.245.39.251 8474 extendable
ip nat inside source static tcp 10.0.0.51 8475 10.245.39.251 8475 extendable
ip nat inside source static udp 10.0.0.51 8475 10.245.39.251 8475 extendable
ip nat inside source static tcp 10.0.0.51 8476 10.245.39.251 8476 extendable
ip nat inside source static udp 10.0.0.51 8476 10.245.39.251 8476 extendable
ip nat inside source static tcp 10.0.0.51 9100 10.245.39.251 9100 extendable
ip nat inside source static udp 10.0.0.51 9100 10.245.39.251 9100 extendable
ip nat inside source static 10.0.0.51 10.245.39.251 extendable
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 0.0.0.0 0.0.0.0 Dialer2 10
ip route 10.1.1.0 255.255.255.0 FastEthernet0/1
ip access-list extended VPN_TRAFFIC
permit ip 10.245.39.0 0.0.0.255 host 203.abc.abc.156
deny ip any any
logging trap debugging
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 50 permit 10.0.0.0 0.255.255.255
access-list 60 permit 10.0.0.0 0.0.0.255
access-list 100 remark CCP_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip 10.0.0.0 0.0.0.255 host 203.abc.abc.156
access-list 101 remark CCP_ACL Category=2
access-list 101 remark IPSec Rule
access-list 101 deny ip 10.0.0.0 0.0.0.255 host 203.abc.abc.156
access-list 101 permit ip 10.1.1.0 0.0.0.255 any
access-list 101 permit ip 10.0.0.0 0.0.0.255 any
access-list 102 remark CCP_ACL Category=4
access-list 102 remark IPSec Rule
access-list 102 permit ip 10.0.0.0 0.0.0.255 host 203.abc.abc.156
access-list 103 remark CCP_ACL Category=4
access-list 103 remark IPSec Rule
access-list 103 permit ip 10.0.0.0 0.0.0.255 host 203.abc.abc.156
access-list 104 remark CCP_ACL Category=4
access-list 104 remark IPSec Rule
access-list 104 permit ip 10.0.0.0 0.0.0.255 host 203.xyz.xyz.19
access-list 104 permit ip 10.0.0.0 0.0.0.255 any
access-list 105 remark CCP_ACL Category=4
access-list 105 remark IPSec Rule
access-list 105 permit ip 10.0.0.0 0.0.0.255 host 203.abc.abc.156
access-list 106 permit ip 10.0.0.0 0.255.255.255 203.102.137.0 0.0.0.255
access-list 106 permit ip 10.245.37.0 0.0.0.255 host 203.abc.abc.156
access-list 106 permit ip 10.0.0.0 0.0.0.255 10.245.39.0 0.0.0.255 log
access-list 112 permit ip 10.0.0.0 0.0.0.255 host 203.abc.abc.156
access-list 124 permit ip 10.245.37.0 0.0.0.255 host 203.abc.abc.156
access-list 150 permit tcp any any eq 3389
access-list 150 permit tcp any eq 3389 any
access-list 177 permit tcp any any eq 1723
access-list 177 permit tcp any eq 1723 any
access-list 177 permit gre any host 10.0.0.2
access-list 177 permit gre host 10.0.0.2 any
access-list 180 permit ip 10.245.39.0 0.0.0.255 host 203.abc.abc.156
access-list 198 permit tcp host 10.0.0.2 eq 1723 any log
dialer-list 1 protocol ip permit
no cdp run
route-map VPN_RMAP permit 10
match ip address 105
route-map PPTP_RMAP permit 10
match ip address 177
set interface Dialer2
route-map SDM_RMAP_1 permit 1
match ip address 101
route-map map permit 100
match ip address 150
set ip next-hop 10.1.1.2
control-plane
alias exec traffic sh ip nbar protocol-discovery stats bit-rate top-n 10
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet
line vty 5 15
privilege level 15
login local
scheduler allocate 4000 1000
event manager environment _email_server 10.0.0.2
event manager environment _email_from notification@mydomain.com.au
event manager environment _email_to itsupport@mydomain.com.au
event manager applet EEM_INTDOWN
event syslog pattern "LINEPROTO-5-UPDOWN.*FastEthernet.*"
action 1 mail server "$_email_server" to "$_email_to" from "$_email_from" subject "Interface down on WAN router" body "$_syslog_msg"
event manager applet test
event none
action 1 mail server "$_email_server" to "$_email_to" from "$_email_from" subject "testing" body "testing"
event manager applet mail_cfg_chg
event syslog pattern ".*%SYS-5-CONFIG_I.*"
action 1.0 info type routername
action 1.1 cli command "enable"
action 1.2 cli command "show running-config"
action 1.4 mail server "$_email_server" to "$_email_to" from "$_email_from" subject "Config changed on router: $_info_routername" body "Config has changed. Here is the updated copy: $_cli_result"
end
I really don't have a clue what is going on!
Any help appreciated.
06-21-2013 12:55 AM
You need to have "ip tcp mss-adjust 1452" on the internal interfaces.
Then update IOS and check again.
Also you configure would benefin from ssome simplification.
