1841 router web-mail & messenger access problem
t_petrop
Hi there,
I'm a little confused because the config look right to me but I cannot connect to the MSN messenger and also the access to webmail (hotmail, yahoo) times-out after a while.
There is no ACL or any kind of policy applied but I have the above access issue. You may check the config and suggest me any further actions.
Thanks in advance.
Tassos
5 Replies 5
baclimon
I had a similiar problem, Im not sure this will help you, but I removed SDM and all started working.
Thanks for the reply,
what exactly do you mean, delete SDM from flash?
Yes I removed SDM, and just configued the router by command line.
jheckart
Level 3
Level 3
Tassos,
I have had similar problems in that certain sites would work, but most would not. This seems to be typical on xDSL lines.
I found that adjusting both the MTU, and the MSS on the internal interface would resolve the problem. I'm not sure if it will help in your case, but it's worth a try.
In my cases, the following has worked:
ip mtu 1492 -> Dialer interface
ip tcp adjust-mss 1452 -> Internal interface(s)
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a00804247fc.html
Let me know if that helps.
Thanks.
Thanks for the tip, it works perfect now.
